Author Topic: E-bay Electronic Ignition Module  (Read 5317 times)
jokke
Re: E-bay Electronic Ignition Module
« Reply #15 on: July 21, 2011, 08:18:28 PM »
is this for AC only, or will it fit BIS?
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
smallcox
« Reply #16 on: July 21, 2011, 09:16:30 PM »
Just to jump on the band wagon, I got one to.
Found that when fitted to some dizzeys the ring was loose and not a tight fit. Managed to find a polish part and it was a snug fit on the shaft. As soon as I started the engine I noticed it run faster and better and had to turn the idle screw down on the carb. I think it's well priced and hope its going to last. Those more expensive kit you mentioned do have advantages but this simple system just replace the troubled points so I'am happy ;D
Funkin Go-nut
« Reply #17 on: July 22, 2011, 12:00:45 AM »
I found that my ring was a bit loose ( :-X ), presumably this is the trigger as it rotates on the dizzy, is it important that this is held in place? Any suggestions as to how this could be done? (I did think of using araldite but i think it would melt as it seems to get quite hot in there..)
I timed it up by hand and took it for a run and it seemed to pull better, but I still had some sputtering when it warmed up (a problem I already had..), I will time correctly as I bought a timing lamp today.
Some points with the one I got, the parts that stated they were black in the instructions were actually red, the leads to the coil were too short and I cut the plastic bung in teh dizzy side wall to hold the rubber gromet in place.
One other point is that the wires in the cap could move and rub on the spindle or catch the rota arm does anyone have a solution?
Other than that its fine.
eben80
    • AircooledVWSA
« Reply #18 on: July 22, 2011, 08:10:44 AM »
My inductive ring fitted nicely luckily. I suppose a loose ring could either be a worn shaft or a ring with incorrect manufacturing tolerance(most likely the latter) :)
The loose wires can be remedied by modifying the plastic insert from a spare original points so that the wires fit in there snugly. As there is no snagging parts on the ring you should be ok as long as there is not too much slack...
Funkin Go-nut
« Reply #19 on: August 01, 2011, 06:16:33 PM »
Ok a quick update.
The inductive ring was loose because it was not made correctly or was the wrong part, a have built up the edge using "chemical metal" as this should withstand the heat in the dizzy..it now fits snugly with no movement.
I used the original plastic insert as suggested and widened the hole, the wires now sit well out of the way of the rotor shaft.
Today I got around to checking the timing and it was a bit out (I had set it up by ear) a quick adjustment of the dizzy and all is now spot on.  :)
The car runs really well now, is quieter and pulls a lot better plus there is no sputtering under load  8)
I wish I had waited a couple of weeks before buying as they were selling the same kits at the Silverstone Classic for £23...  :(
Oh well on to the next job..
robinoz
« Reply #20 on: November 23, 2011, 07:35:23 AM »
So whatare the options for a roterless distributor ??
« Reply #21 on: November 23, 2011, 01:34:19 PM »
This electronic ignition appear to be great. The participants of the discussion seem to be from 126 aircooled owners. Here is my stupid question. Presume this will also work well with the 126 Bis. Jokke did ask the question.
« Reply #22 on: November 24, 2011, 09:35:15 AM »
MIght need some lateral thinking and modification for the BIS.
I think the dizzy shaft bit is more-or less the same on the air cooler and boiler BIS.
The points on the boilers are bigger so how one would get around that I dunno, perhaps drill new holes in the plate to fit the pickup.
I have a boiler dizzy I will have a look at some time and report back.
My module thing hasnt missed a beat since installed ;D
Tomasz
« Reply #23 on: November 24, 2011, 01:38:16 PM »
I wonder which is better - this one or the accuspark one:
 http://www.ebay.co.uk/itm/Fiat-126-AccuSpark-electronic-ignition-kit-/190569972829?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c5edb045d
which is cheaper. Or maybe they are the same one! I think i may go for one of these when i have some spare money.
btw hello everyone, i have not posted in a while but i am using my 126p again now!
Funkin Go-nut
« Reply #24 on: November 24, 2011, 02:01:46 PM »
Mine is still working fine as well  ;D
Tomasz, if you are in Norwich you can have a look at a fitted one if you like?
Tomasz
« Reply #25 on: November 24, 2011, 02:35:50 PM »
I might take you up on that offer nearer the time. My sister in law said she saw a 126 the other day around Bracon Ash and thought it was me at first then noticed front fog lights. Could that have been you?!
I live around the Golden Triangle.
« Last Edit: November 24, 2011, 02:45:42 PM by Tomasz »
Funkin Go-nut
« Reply #26 on: November 28, 2011, 10:32:23 PM »
Could have been, if the fogs were big and yellow, the 126 was white and it was driven by a big bloke with a greying beard :-)
I live just the other side of Taccolneston and work in Thorpe and use the 126 most days for work.
Tomasz
« Reply #27 on: November 29, 2011, 10:01:19 AM »
Haha must have been you! Come to think of it, i think i saw you bombing along the Norwich road a while back.
(sorry to go off topic everyone)
back on topic: i think i might give the accuspark one a go after christmas.
