Author Topic: E-bay Electronic Ignition Module  (Read 5316 times)
eben80
    • AircooledVWSA
« on: June 30, 2011, 07:16:37 AM »
Hi all,
Anyone else using one of these?
http://cgi.ebay.co.uk/Fiat-126-distributor-Electronic-Ignition-Ultra-Spark-/350439087489
I bought it before I bought the car  :o
I fitted it and it seems to work quite well...  Did one fail on anyone yet?
Of course I carry a mechanical spare just in case...
Re: E-bay Electronic Ignition Module
« Reply #1 on: June 30, 2011, 08:46:45 AM »
I've been using one for about a month now and it works very well indeed :-X
eben80
    • AircooledVWSA
« Reply #2 on: June 30, 2011, 08:49:25 AM »
Lol so we're in the same boat...   ;D
Well here's to reliablility  :thumbup .....
Only problem I had with it is the pooty grommet it came with... did you replace yours?
« Reply #3 on: June 30, 2011, 09:06:46 AM »
I had a spare plastic bit, you know the one that connects the wires and the points spring to. So I made the hole a little bigger, and sealed the wires in place with some exoxy glue.
I am finding it to be way better than the electronic ignition I had before. The one I had before was pre-programmed, I think the programmer must have had a heavy night before prgramming mine :cry:
eben80
    • AircooledVWSA
« Reply #4 on: June 30, 2011, 09:09:59 AM »
I might have to look for a spare plastic bit then.
What kind of unit did you have before?
While I was looking for a unit I only found 123 and another German version...
PS: Are you the only African in the village? Where from?  :)
« Reply #5 on: June 30, 2011, 09:46:01 AM »
I'm from a little tin pot country called Zimbabwe. Mostly unheard of and lead by a jolly good fellow the world loves. It was there in my youth I owned a 500 and a 500 giardiniera and that started me on fiats :)
Yes the 123 ignition was what I had before. I am annoyed with it as I paid alot of money for it.
It took me a while to realise it was the cause of many of my overheating problems so I guess warrenty has long run-out so probably will get no help from them.
eben80
    • AircooledVWSA
« Reply #6 on: June 30, 2011, 09:52:51 AM »
Ah so you were my northern neighbor :D
Yes the 123 does seem to be a sledgehammer for a nut :)
When I installed the module I did have to turn the dizzy quite a bit though... to get the timing right again... I would have thought it would stay more of less the same.
« Reply #7 on: June 30, 2011, 09:58:33 AM »
Did you use a timing light?
Yes I found it a bit of a pickle to get the dizzy so the wires were roughly where I wanted them but I did a bit of hopping teeth and got there in the end.
Southern neighbour then...so I'm now not the only african in the village!! :$
eben80
    • AircooledVWSA
« Reply #8 on: June 30, 2011, 10:09:51 AM »
Timing-light? WHat's that?  ;)
No all my tools got stolen just before I left London  :cry:
I still need to buy:
A socket-set
Torque wrench
Feeler gauge
bolt extractor
..what am I missing?
I installed it by cranking it with a pole on the starter switch while slowly turning the dizzy untill it started.
I then found the highest idle speed and just retarded it a little... seems to work ok....
« Reply #9 on: June 30, 2011, 10:33:57 AM »
I'd get a timing light.
They can be little sods these baby fiat engines. To get the best of the 26hp the timing has to be spot-on.
eben80
    • AircooledVWSA
« Reply #10 on: June 30, 2011, 11:28:52 AM »
I'll keep that in mind thanks  :D
Funkin Go-nut
« Reply #11 on: July 20, 2011, 05:24:14 PM »
Ive just bought one of these, does anyone have a pic of the module fitted?
I want to make sure i get it right as the only instructions are on the back of the blister pack it came in...
It doesn't seem a lot for £50 either.... :o
FGN
« Reply #12 on: July 20, 2011, 07:58:16 PM »
Instructions? It was so simple.
The module fits where the points were and the round thing slips over the lobed rotating bit.
Funkin Go-nut
« Reply #13 on: July 20, 2011, 11:08:59 PM »
It almost looks too simple so I ended up feeling nervous, so I thought I would check with someone who had fitted one before I went ahead.... ;D
« Reply #14 on: July 21, 2011, 09:33:00 AM »
 ;D
They are rediculously simple. I recon for the price you getting pretty much what you pay for. I like the way they have tailored it to work with either a single or double chimney set-up on the coil.
The only part that I found a bit annoying was I didn't remember where the rotor was pointing when I took the dizzy out to fit it.
As a result I had to crank the engine and turn the dizzy till the engine fired, then fine tune the timing with a timing light.
50 quid versus the 200 or so for the other type of ignition...lets hope the simple things in life are the best  ;D
