Author Topic: running sweet as a nut (for now)  (Read 5208 times)
nrg19uk
« on: June 21, 2011, 09:48:50 PM »
howdie folks ive been messing again :-) i kept getting the dreaded oil warning light come up once driving for a long time, so i changed the sensor made no diffrence, changed the oil, set timing made no diffrence starting to get a bit peed off i was scanning the net for aircooled tips so i turned my idle up etc still the same problem so i decided to buy a oil pressure and oil temp gauges, fitted those.
oil pressure on start up 75 psi once driving would drop to 50 then once got upto temp would drop to 40/25 depending how big the hill was.
 the temperature got to about 125 and stayed steady
i searched the net searched the forum!!! banged my head against the wall and came up with two things either the crank bearing or the timing.  :cry:
so i decided to tackle the timing first £50 later
new coil
new plugs + leads
new rotor
new condensor
new dizzy
and new points
set the timing and yippie ki-yay it only bloody runs sweet as a nut!!
oil pressure on start is 75 psi and drops to 60/55 psi
oil temp is sitting at 100o
picks up really well now starts first time :-) ive even over took someone!!! im over the moon  ;D ;D ;D it even feels alot cooler in the engine room :P
Neil gargaro
Re: running sweet as a nut (for now)
« Reply #1 on: June 21, 2011, 10:01:11 PM »
Sounds a bit odd the high pressure to start with.
Mine stays pretty constant at 40psi hot cold or whatever. Remember there is a spring pressure release valve which is the bit that presses against the cam.
One thing is for certain, you have pressure and you are getting closer to solving the problem.
I did a daft thing when putting mine back together, proir to that the rear bearing had a big piece ripped out of it. I put it together and got the washer on the front end of the crank the wrong way and the oil light refused to play ball.
Kipster
« Reply #2 on: June 25, 2011, 05:36:47 AM »
I think its quite normal for oil pressure to drop, as the engine warms the oil thins so flows more easily.
I'm confused how altering the ignition circuit can increase the oil pressure though?
nrg19uk
« Reply #3 on: June 25, 2011, 09:48:52 AM »
I thought it was a bit strange but it makes sense when you think about. Oil gets warm and becomes thinner so to speak, my engine was running red hot there for piss thin! Lol
Well its running so much better I'm not sure if I'm getting a higher pressure on startup because the thickness of the oil I'm using the castrol classic stuff,  It seems to have settled down to 75 psi and stays constant.
I seem to have developed a misfire every now and then. I've cleaned the fuel tank changed the lines and installed a see througth filter but when the engines running it barely fills the filter It doesn't look like enougth fuel coming througth, but if i take the feed from the fuel pump off it seems like it's gushing througth?????
Also I struggled to start her up the other day before strobe lighting the timing so I advanced the ignition a bit, my god the car was like a rocket,  the problem was when I turned the ignition off it carried on running lol
Neil gargaro
nrg19uk
« Reply #4 on: June 25, 2011, 01:56:47 PM »
ive been having a play this morning with my fuel pressure tester have a look and tell me what you think  :o
http://s122.photobucket.com/albums/o254/nrg19uk/?action=view&current=IMG_1177.mp4
Neil gargaro
nrg19uk
« Reply #5 on: June 26, 2011, 05:10:28 PM »
Oi you all in the garden having a beer in this lovely weather
Spare some time and give me some feedback  :P
Is this normal for the pump pressure to be so erratic? Or is
My pump is knackred?
What's the normal pressure? Should it be constant
Or
Doesn't it matter?
Neil gargaro
DEYAN IYI
« Reply #6 on: June 26, 2011, 06:07:05 PM »
Hi!
Nice dance! ;D I don't know how normal it could be according to the fuel line back to the tank. You'd better check if the valves in the pump are working proper. Release the lines and blow in both directions. Watch out, cos usually is tasty, but not dangerous, we have it already in the blood :$
It must pump minimum 40dm3/h at 2000rpm.
14,7...24,5 kPa (0,15...0,25 kg/cm2) but no data about rpm, so have them like min&max.
The rod must come over the seal surface exactly 1,5mm (other source says 1...1,5mm and 2,4mm stroke), before it's pushed by the eccentric on the camshaft. If it's more or less, you can adjust it by fitting 0,3-0,7-1,2mm seal between the heat isolator and the block.
 :thumbup
« Last Edit: June 26, 2011, 06:17:57 PM by DEYAN IYI »
Kipster
« Reply #7 on: June 26, 2011, 06:16:03 PM »
at a guess i dont think that is right, :D  have you checked your pressure gauge on another vehicle..
Jumping pressure gauges usually indicate that the pressure is escaping, and then resealing. Pressure relief valve?
nrg19uk
« Reply #8 on: June 28, 2011, 10:15:21 PM »
Thanks for that deyan/kipster I can't seem to see why it's doing it apart from
It's knackred.
I think I'm gonna invest in a electric fuel pump.
 Has anybody fitted the cutoff kit to there's? I've read it's a requirement for retro fit fuel pumps also the solid state fuel pumps should be fitted level with fuel tank for correct flow???
Neil gargaro
« Reply #9 on: June 28, 2011, 10:30:20 PM »
I'd say that is about normal bahaviour.
Remember the pump is operating like a bicycle pump. There is a bypass that goes back to the tank to ensure there is always flow through the pump. This will also help keep the pressure up at higher fuel usage and keep the pressure down on low usage.
Then to throw a variable into the equation the float is opening the valve from time to time. I'd expect the pressure to jump about like a crazy thing.
I run an electric pump, fuel line pressure is more constant and there is less cranking to start the engine when the fuel in the bowl evaporates out. ::)
nrg19uk
« Reply #10 on: June 29, 2011, 08:16:47 PM »
What pump are you guys running? You got any pics of your setup?
Neil gargaro
« Reply #11 on: June 29, 2011, 08:19:03 PM »
I think Dajwid had a topic of a fuel pump he bought, his pump is slightly different to mine however same principal.
I have a square shaped facet pump and the same regulator that Dajwid has.
nrg19uk
« Reply #12 on: June 29, 2011, 08:22:09 PM »
Yea I have seen his I'm looking into something similar. have you blanked off the return from the carb? Does your pump stop once it's reached its pressure when it's full?
Neil gargaro
« Reply #13 on: June 29, 2011, 08:41:28 PM »
I did have a carb that did not feature the return, this was a problem as the regulator would every now and then not open.
A bit of experience with regulators tells me that once the bowl is full, the pressure will go up. The regulator reacts by closing-down. Now the regulator thinks there is too much pressure and stays shut.
I then changed to a Dellorto FZD which has a bypass fitted however there was no restriction as there is in the original Webber. At heavy load I was litterally running out of fuel as there was no/little flow into the fuel bowl.
I then machined-up a restrictor the same size as the one in the Webber and since then have never had a problem at all.
So in answer to the question yes bypass needed, no problem with original carb. Any other carb make sure there is a restriction going on the fuel line back to the tank.
I must add I am also very pleased with myself as mine is running sweet as a nut too  ;D
With the original cam I could only make a maximum of 40 mph up a hill near my house. Now I can do nearly 50 with the new cam ;D
nrg19uk
« Reply #14 on: June 29, 2011, 08:45:26 PM »
Nice I'll be over the moon with that! What camshaft is it? How much that set you back?
I've been looking at the facet fuel pumps
Off flea bay for about 20 notes but I've read they need a cut off kit?? Is that rubbish?
Neil gargaro
