Author Topic: 795 ccs Cylinder Head  (Read 3011 times)
« on: May 30, 2011, 07:27:16 PM »
After waiting for months I finaly got the cylinder head back from the specialist today. It is a reworked 126 head that was described as a "Stage 1" head back in the 80's. The engine work was done by Italtune (went onto be Lanciana) in London as part of a 795 ccs conversion using Alquati parts & possibly VW pistons & barrels (yet to identify as just described as a Big Bore Kit) . The head has now undergone a full inspection with additional improvement work on the inlet and outlet ports, mods to the valve seats & valves plus I gave the guy the original Alquati inlet manifold that he has polished out and matched to the head as I thought that area could be improved. The manifold takes the rare Weber twin choke 30 DIC carb which did not come with the engine but I found one in a box of old carbs at Retro Rides which I got for a song then sourced another one from a guy in New Zealand so things are shaping up and moving on  ;D
smallcox
Re: 795 ccs Cylinder Head
« Reply #1 on: May 30, 2011, 09:47:28 PM »
Rusty,
Like the head work, the big question is when's it going to be running? and in the back off that 500
Allan
« Reply #2 on: June 26, 2011, 10:09:33 AM »
Which vehicle was the 30DIC OE on?
« Reply #3 on: June 26, 2011, 11:41:57 AM »
Very nice  :D :D :D :D :D
« Reply #4 on: June 26, 2011, 11:44:41 AM »
The Weber 30DIC , as far as I know , was only ever fitted to the 850 Sport Coupe as standard which is why they are a bit rare. I have two carbs , Weber and an Italian made Holley Europa which are identical apart from one has brass butterfly sipndles , the other has steel. They were a popular tuning mod for some engines hence the Alquati manifold from the early 80's. When I got the 795ccs engine the seller told me that he preferred the Dellorto FZD 32 28 which I have also. He never went into details about why but as he used to race some pretty heavy duty cars and bikes on the European circuits I guess that the Dellorto gave him that little bit more. I want to try out the Weber at some stage on a 652ccs engine to see how user friendly it is. Nice to have a bit of performance but I also want to pop to the supermarket  ;D
Allan
« Reply #5 on: June 27, 2011, 01:28:49 AM »
Thanks uncle R. There must be 850 coupes lying around all over NZ.
« Reply #6 on: June 27, 2011, 05:39:41 AM »
Well I found 2 cars in Horopito. One was pretty much complete. The other one I could not get round to the back to see in the engine compartment.
