Forget about the suppressor. Wire the coil as the diagram above, if you are using standard HT suppressor leads and not copper HT leads, With a modern car radio and aerial you shouldn't have problems with radio interference, which is all the suppressor is used for. Remember start with the basics, any other problems can be sorted out later.
