Author Topic: Coil wire from distibutor  (Read 5209 times)
Re: Coil wire from distibutor
« Reply #15 on: April 28, 2011, 10:50:10 PM »
The light blue dot is the suppressor
The dark blue dot on the wire (distributor) goes to the blue dot on the coil
Is the wire with the pink dots on the same wire as its going to earth (negative)
Or is there 12volts at the terminal?
robinoz
« Reply #16 on: April 29, 2011, 05:39:12 AM »
The wire with the dark blue dot does it go to either 1of them 2 prongs marked with a dark blue dot
The only 12v power is from the wiring loom I think
« Reply #17 on: April 29, 2011, 08:05:49 AM »
You can use either of the 2 terminals they are the same.
Does the wire marked with the pink dots go to the nut holding the coil? If it does that is not the 12volt supply to the red dot on the coil.
robinoz
« Reply #18 on: April 29, 2011, 08:46:30 AM »
No the wire with red dot goes into wiring loom the wire x2 holding coil on goes Into wiring loom aswell
So the supressor is what I thought was a condenser fastened to the coil?0
« Reply #19 on: April 29, 2011, 09:12:32 AM »
Yes the suppressor is the one that is fitted to the bottom of your coil.
Connect the wire with the red dot to the red dot on the coil and that should be it, It maybe worth checking that there is 12volts on that wire when the ignition is turned on :thumbup
robinoz
« Reply #20 on: April 29, 2011, 09:29:16 AM »
Great I understand now I did say stupid terms got my battery on now see if it will start since I rebuilt it
Thanks again been a great help
robinoz
« Reply #21 on: April 29, 2011, 11:36:49 AM »
 ;D and my baby now runs I am so pleased thank u all
« Reply #22 on: April 30, 2011, 07:03:11 AM »
RESULT  :wave
How about some pictures of the little beast :D
robinoz
« Reply #23 on: April 30, 2011, 08:50:11 AM »
hi mate Im having truble compressing my pics for this site will get the sorted soon and put them in the rest section but I do have a load of pics on a Facebook account I set up
Robs fiat niki Pyle is the account name a pics are open for anyone to view let me know what u think
