Author Topic: whipping up an su carby adaptor, just for fun:)  (Read 5578 times)
phreak97
  • Niki!
« on: April 16, 2011, 02:15:22 AM »
I got talking to AllyNiki about possible carby upgrades, and being that I work as a mini specialist mechanic, I decided an HS2 (SU 1 1/4") carby would be a suitible replacement.
today I bought some steel bits to make up a crude manifold adaptor, and dug out about five hs2s from my shed. all are in varying siezed states, so my first job is going to be building one working one from the bits:P
alot of people are afraid of su carbys because of the different needles and springs and not knowing what they need, but whatever carby you bolt on isnt going to be jetted correctly, and at least su needles are well documented and I know theyre a great little carby with no complex bits:)
phreak97
AlleyNiki
Re: whipping up an su carby adaptor, just for fun:)
« Reply #1 on: April 16, 2011, 02:19:36 AM »
I've never heard of the HS2, what are the specs?
phreak97
  • Niki!
« Reply #2 on: April 16, 2011, 02:35:58 AM »
it's a 1.25" (32mm) side draught variable venturi carby with an oil damper. they came standard on 998 and 1100cc minis among other british cars.
my plan is to get the dash pot spring from a twin-su setup (red spring I believe, but will check) because it'll be breathing about half as much as a mini motor. the needles will be a bit of trial and error. I'm lucky enough to have occasional access to a dyno, so I'll hopefully be able to check the air-fuel mixture once I get it close enough.
phreak97
AlleyNiki
« Reply #3 on: April 16, 2011, 04:26:50 AM »
Wow, now that sounds like a true mod. :O
What sort of gain do you expect to get performance wise?
phreak97
  • Niki!
« Reply #4 on: April 16, 2011, 06:41:08 AM »
probably not that much lol, but it will be nicer on cold starts and smoother to drive:)
phreak97
Allan
« Reply #5 on: April 16, 2011, 08:06:13 AM »
I can't put my hand on the information but one of the carbs from a 1275cc Cooper S which was feeding 634cc by itself should go straight on.
phreak97
  • Niki!
« Reply #6 on: April 16, 2011, 08:13:11 AM »
lol that's an hs2 with an m needle, I don't know what needles I have yet
phreak97
phreak97
  • Niki!
« Reply #7 on: April 16, 2011, 01:04:26 PM »
I made up a little manifold tonight, hopefully I'll have time to try it out tomorrow.
so far I've found a GZ needle and an AN needle. their fuel curves sit either side of the cooper S M needle, so I'll just have to see how I go I guess.
I've got two more needles but theyre still stuck in carby pistons so I dont know what they are yet.
you can do your own comparisons here: http://www.mintylamb.co.uk/suneedle/
unfortunately the position of the carby in the niki means its going to be a bit harder to swap out needles than it is in a mini, but I guess once I've got one I'm happy with it'll be in there forever.
« Last Edit: April 16, 2011, 01:07:31 PM by phreak97 »
phreak97
smallcox
« Reply #8 on: April 16, 2011, 02:48:28 PM »
Hi 97,
You work with mini's then. You properly well suited to the Su carb. I myself made an manifold that fitted 1 and half inch su. When calibrating it I found no matter how thick a needle i used it run over rich so had to remove the piston spring and run it with out one even the 4 oz spring went to rich but that was on a 1 and half it may be different with a smaller carb.
other than that I still run an SU in now the turbo version 126 and can say its faultless ;D
AlleyNiki
« Reply #9 on: April 16, 2011, 06:25:23 PM »
What sort of head will that manifold fit onto? Oh and how did you do it? Looks damn clever to me!
Alastair
phreak97
  • Niki!
« Reply #10 on: April 17, 2011, 01:48:20 AM »
smallcox, yep I'm a third year at Minisport (www.Minisport.com.au).
1.5" is a bit too big for a 126, I'm not suprised you had problems with it, you just cant get the airflow.
If youre running a turbo it's a bit of a different story:P
AlleyNiki, it'll go onto the standard head with the original plastic adaptor in place. I just got a 30mm square tube and a length of thick flat steel, traced the base of the su and the base of the niki carby onto the flat steel, cut them out, then cut square holes in them to match the tube. I cut the tube at the correct angle to have the su float bowln sitting level, then welded it all together:)
I believe the del orto fdz manifold fits an su hs2 as well, so I guess my manifold fits a del orto fdz
phreak97
AlleyNiki
« Reply #11 on: April 17, 2011, 05:39:04 AM »
Let me know how it goes, when are you trying it?
phreak97
  • Niki!
« Reply #12 on: April 17, 2011, 12:48:15 PM »
I got it installed tonight, all is not well however, aside from not being tuned yet so limiting my revs to about 4000, it's hitting the top of my engine bay:(
tonight I had to recut the adaptor to be shorter because I'd miscalculated the space I have, and even with it being the shortest I can make it it still hits. the only way to make it shorter now is to make the flanges thinner.
I'm going to see if I can actually get it tuned up nicely before I bother with that though.
phreak97
« Reply #13 on: April 17, 2011, 11:09:33 PM »
Interesting stuff. I plan on getting into SU carbs one day, found a book on the internet that seems to be a good starting point:
How to build and power tune su carburettors by Des Hammill
phreak97
  • Niki!
« Reply #14 on: April 18, 2011, 09:40:34 AM »
oohh I'll have a look into that. David vizards tuning books are great too.
i changed the needle today and the fuel mixture feels ok but the SU opens half way then starts to drop again, so I'm not getting much power.. I'll talk to the guys at work tomorrow and figure it out
phreak97
