Author Topic: whipping up an su carby adaptor, just for fun:)  (Read 5579 times)
smallcox
Re: whipping up an su carby adaptor, just for fun:)
« Reply #15 on: April 18, 2011, 10:15:58 AM »
 See your thought off pattern their 97,
I used a hs4 su as a normally asperated engine and that required no spring at all and work wonders, the turbo uses the later su which is used as a blow through set up and that required an 8oz spring, both carbs are reworked to flow better which involved internal modes. I have heard people comment in the past that 1.5 su is a bit bit, but it's smaller than a 40weber and as the piston starts from base the size self correct itself. When choosing a carb it's sizes is based not on size of engine cc but per cyclinder cc so if your engines was a mini engine with 4 cyclinders the 1.5 su is a bit small? A make-beleive 126 four cyclinder engine would make our engines 1300cc yes almost the same as an A series, a 1.25 su is only just bigger than the standard carb fiat fitted in the first place. :D
Ps I had days off trouble when first setting up that carb, I know it's trail and error but if your engine power goes flat when the throttle is fully opened and the carb is in sound condition it may be under fueling. try holding the choke and see if this make any notible difference ??? good luck
« Last Edit: April 18, 2011, 11:06:40 AM by smallcox »
smallcox
« Reply #16 on: April 20, 2011, 01:48:42 PM »
 just though off something that happened to my su manifold in the early development stages that may explain your power drop when throttled. Manifold to head seal(gasket) not sealing. Remember these little engines vibrate badly and I had trouble keeping it sealed when i build my first manifold as there is very little room between the head nuts and port to get a good seal :-
