Author Topic: Summer heat and the BIS  (Read 1832 times)
markymarc
« on: February 27, 2011, 07:18:58 PM »
Sorry here is another quick question i have just thought of which i meant to ask!!
I know the BIS suffers from overheating in the summer, is it advisable to fit an extra fan inside the engine bay?
If so what is best, and position?
Advise from those in the know please and maybe a supplier?
Thanks again
marc
Re: Summer heat and the BIS
« Reply #1 on: February 27, 2011, 09:59:07 PM »
You wont achieve anything by putting another electric fan in the engine compartment, the standard radiator fan on the bis is very powerful and moves allot of air [-/  once the engine reaches its normal running temperature and the engine lid is closed it pulls cool air across the entire engine.  The problem is due to lack of maintenance of the cooling system, With the thermostat located at the bottom of the engine it is susceptible to dirt/rust clogging the operation of the thermostat and failure if not serviced on a regular basis,  I usually flush the whole system out every couple of years using something like radflush and replace the thermostat, and have never had a problem with overheating even in the height of summer, cruising at 65/70mph on motorways for hundreds of miles :)
« Reply #2 on: February 28, 2011, 07:53:52 AM »
sounds to me that your fan might not be cutting in if its overheating? have you left it on the drive way to check the switch is working, I beleive it has 2 speeds so you need to make sure it is operating as designed...
« Reply #3 on: February 28, 2011, 02:56:47 PM »
I thought long and hard before buying a Bis given its overheating reputation but as Pete126 says, if the the cooling system is maintained regularly, the car will be fine. My Bis has not given me any overheating problems despite being stuck in traffic on the motorway for a couple of hours on a few occassions.
In addition, as a matter of course, always keep an eye on the engine coolant temperature gauge. I tend to get a bit concerned if the needle goes beyond the halfway point (the needle normally stays at the halfway point, being the optimum temp) or it takes a bit longer than usual to warm up. Also always, watch the insufficient coolant level warning light as well, although this indicator can sometimes play up a bit.
On the radiator fan, others have opted to install an override switch as a precaution, but personally, I do not see the need to do it.
There is also the thermostat conversion kit that others have used. I am not sure whether Ricambio still sells them. Pete126 has this in his Bis.
Others have converted the cylinder head gasket to copper headgaskets, they expand with the heat rather than split like fibrous ones.
« Reply #4 on: February 28, 2011, 06:43:04 PM »
My BIS fan used to blow great amounts of hot air out the left hand side, great place to stand in winter  [-/
Draigflag
  • Got a New Abarth 500 too!
« Reply #5 on: February 28, 2011, 07:33:30 PM »
What if you removed engine cover, removed parcel shelf an opened all windows? Would this help!?  ;D
« Reply #6 on: February 28, 2011, 07:43:43 PM »
Good idea, surely that would then make it an aircooled :oops:
