Author Topic: aircooled passed its mot!!!  (Read 7228 times)
nrg19uk
« on: January 27, 2011, 12:20:41 PM »
yipppiieeee finally got the aircooled back on the road!!!  8)
on the way to the test centre for the retest for the lights and the bit of welding i ended up hittting a pot hole the exhaust manifold decided to come away at the rear of the engine so i crept into the mot place without reving ;-)
whats the best way to fix it?
 helicoil or rethread for bigger bolts? what size helicoil would i need
« Last Edit: January 27, 2011, 12:22:37 PM by nrg19uk »
Neil gargaro
Re: aircooled passed its mot!!!
« Reply #1 on: January 27, 2011, 01:15:25 PM »
Congrats on the MOT , always a great moment  ;D
Assuming the bolts holding the manifold elbow to the head have stripped then I would go for helicoils as if you go for bigger bolts there is no way back if & when they go . Also if you go for studs instead of bolts then you should not have to face the problem ever again. The thread size is M8 x 1.25 & I was quite amazed this week to see that you can get a thread repair complete kit on eBay for less than £20. I will take a pic of my set up & post it as there are other things you can do to make it all sound  [-/
nrg19uk
« Reply #2 on: January 27, 2011, 04:33:49 PM »
well i took the engine out to have a closer look at the leaky exhaust also to cure a leak from the rocker i can never seem to stop!!!
the exhaust is completly wrecked! im not even gonna bother welding it im just gonna go back to a standard pipe. whats more annoying is this was a new exhaust fitted last year and sat on the drive since!!! a maximum of ten mins use!!
cheers rusty im gonna purchase a heli kit asap theres someone selling a ss stud set on flea bay this any good or would normal steel be better?
aircooled over the pit at mot shop not much room for error!!
Neil gargaro
« Reply #3 on: January 27, 2011, 06:42:20 PM »
That exhaust looks poorly but at least you put a bandage on it before you put it out of its misery  :oops:
I think that there are a number of guys on here that will see that exhaust and share your pain  >:(
Seems you get what you pay for with exhausts & that exhaust box shape suggests it is one of the cheap imports that appear to be made of "potty putty" or something similar plus there are issues with the mounting brackets.
If you are going standard then the original shape & fittings work the best in my experience.
Looked at the stainless set on eBay , is that volksbolts? , could be a reasonable deal & you get twice as many as you need for a 126, studs seem to be studding (threaded all along) which should not be a problem & they have 100% rating.
My set up is steel studs into head with stainless flat spring washers & dome nuts, then stainless flat spring wahsers & stud connectors on the steel elbow studs backed up by a locking stainless grub screw into the stud connectors. So you have all stainless on the exposed bits & the steel protected from the elements. Posting a pic but ignore the bit of "bandage" and the clip. It got damaged and the exhaust wrap disintedrated at the same time as I had the oil leak so my engine bay is pretty much coated in fur. Also you can see that high temp paint is pretty rubbish afterb about 6 months  :o
nrg19uk
« Reply #4 on: January 27, 2011, 08:16:13 PM »
Yea that's the guy, whilst on eBay I brought the helical kit aswell as a new rocker cover gasket.
I paid 100 quid from that Chet guy off eBay for that exhaust not the cheapest out there And as you say looks like it's made of old fords ;-) it snapped of completely above the weld I don't think the brackets where a problem as it was solid. But I'm missing the bolts out of the block.
I may get a stainless one made at a later date if I'm feeling rich one month and do away with the manifolds if you can.
That's a tidy looking setup you have there! The paint has gone the same on mine there's a heat paint I was looking into that you cook painted like a cheAp powder coating system just another wild thought.
Neil gargaro
grubscrew
« Reply #5 on: January 28, 2011, 04:14:49 PM »
Now exhausts is what I`ve experimented on:The best and only way is to get the exhaust either new or good condition,take it to a shot blasting man,get him or her to blast it then hot flame sprayed  then you can paint it what ever colour you like.My exhausts have lasted more than 7 years.Dont waste your hard earned cash on simply spraying a new exhaust IT COMES OFF AFTER 2 or 3 OR THREE "burns"
All things Italian.
« Reply #6 on: January 28, 2011, 06:13:13 PM »
good on ya neil you can run down to me this summer for a barbie now , dont chuck the exhaust if you ever take the engine out then you can fit everything in place tack then weld it back up i think somewhere the exhaust has been overstressed and made it fail , remember that exhaust i had from you that fitted the 500? i had to make some 6mm spacers (between the manifold and exhaust) to push it away from the starter motor and then fabricated some brackets.  [-/
nrg19uk
« Reply #7 on: January 28, 2011, 06:54:03 PM »
Yea I'm up for that Mick you've moved now haven't you? Let's see a pic of the exhaust.
 I can't be arsed with it I think it was restricting more than the original anyway I will keep hold of it I'm sure you can do something with it.
Grubscrew how much it cost to get that done? Did you have a choice of colours? It's not a enamel stuff chips easy?
Neil gargaro
grubscrew
« Reply #8 on: January 28, 2011, 07:28:33 PM »
50 or 60 quid,then the cost of the H.T.paint that you do yourself.Bear in mind ant exhaust held in that way is under extreeme stress,better to get a different type to the poorly one you had.
All things Italian.
« Reply #9 on: January 28, 2011, 07:52:29 PM »
Congrats  [-/  I guess you'll be  **- a lot now. I only feel safe when driving over a pit if there's someone there to direct me (there's always tyre rubbing with the 126  :P)
nrg19uk
« Reply #10 on: January 28, 2011, 08:35:51 PM »
It was a bit bottom twitching they wouldn't jack it up over the pit because they was worried the wheels moving in lol
Neil gargaro
skelz
« Reply #11 on: January 30, 2011, 04:00:28 AM »
can you repair threads without drilling the hole out first.. My bottom bolt of the exhaust elbow needs a helicoil or similar inserted...
« Reply #12 on: January 30, 2011, 09:15:48 AM »
The answer to your question is yes because I have just done it on the rocker mount studs on my cylinder head but it is only really possible because you are working with the relatively soft aluminium head. The M8 bolts & studs have a thread pitch of 1.25 mms so to fit a helicoil the holes have to be tapped out to M10 x 1.25 ( M10 fine). The tapping size drill for this thread is 8.75 mms. As long as you can get the tap started in the hole , so best to start with a taper or 2nd tap, then it should be OK. Bear in mind that you may be removing a bit more swarf/metal than normal so it is a good idea to clean the tap every now and then , especialy with a blind hole. Also I found that cotton buds were ideal for cleaning out the metal particles  [-/
nrg19uk
« Reply #13 on: February 06, 2011, 12:34:39 AM »
hi folks
more troubles!! i fitted the new standard exhaust sounds so much better runs smoother aswell.
but when ive been cruising around on the motorway sitting at 55-60 after a few hills the oil light came on went off when i rev or drop down a gear it goes away.
ive got plenty of oil that classic stuff, nice warm air coming in cabin, also thermostat opening fully
 it seems to really struggle up hills also flat out down to 35-40.
im gonna check the timing tomorrow also that im using the correct oil my haynes manual saying:
sae 15w/40 castrol gtx
http://www.castrol.com/castrol/iframe.do?categoryId=9024084&contentId=7044829
this website says: MAGNATEC 10W-40 A3/B4
i think im using sae 30 classic
any further ideas?? im a bit mythed
Neil gargaro
« Reply #14 on: February 06, 2011, 07:51:06 AM »
The poor performance could just be that it is slightly out of tune. Has the centrifugal oil filter been cleaned out recently & what is the air filter like ? Easy to check if the air filter is clogged just disconnect it or take it out & see if it affects the running  [-/
