Author Topic: aircooled passed its mot!!!  (Read 7230 times)
nrg19uk
Re: aircooled passed its mot!!!
« Reply #15 on: February 06, 2011, 12:07:58 PM »
I cleaned that last year I haven't driven it since also the airfilter looks clean.
 I may change the oil,
Neil gargaro
skelz
« Reply #16 on: February 06, 2011, 12:33:15 PM »
i was surprised the difference an oil change made to mine
« Reply #17 on: February 06, 2011, 12:45:21 PM »
OK so check the usual suspects , air being drawn in at base of carb , contact breaker points & ignition timing  [-/
nrg19uk
« Reply #18 on: February 06, 2011, 04:50:20 PM »
well that was interesting  :- one burn, one cut, and a couple of shocks later and the timings setup.
adjusting the dizzy the car has a little miss fire giving me a shock makes me jump then i burn myself on the exhaust!!! is that suppose todo that??
right getting down to business timing was about 4 inches advanced got the strope out and setup according to the haynes manual cars alot smoother and not so loud. pulls alot better but asoon as i put it in 4th gear thats all lost.
would the orginal advancement make the engine hot? also the line was very jumpy sometimes every so often it would be two lines only once or twice is this normal?
sorry about all the constant questions ill buy you all a beer at the next meet ;-)
Neil gargaro
« Reply #19 on: February 06, 2011, 06:07:22 PM »
 :D Mmmmm! Beer
Yes it is meant to do that , that old hot exhaust will burn you every time   </4
Oh you mean the shock ! That HT electricity will take the easiest path it can to get to earth . The system is designed so the preferred route is from the coil to dizzy cap to plug leads via carbon brush then rotor arm & lead contacts in the cap. Then leads to plugs and the spark gap. So if your car prefers to give you a belt of HT electricity instead then you were the path of least resistance.
So could be plugs , modern supressed leads break down in time plus check leads have good contact & are pushed right home . Check dizzy cap & rotor arm condition plus that the cap seats down nicely.
If your timing was 4 inches out I am very surprised that the car would start at all. Anyway , not in the 126 Haynes manual , but in the older 500 Haynes . "Overheating can be caused by timing being a long way out , a carburettor fault & weak mixture or air leak beneath the carb"
Can I have my beer now as all this chat has made me thirsty  :beer:
nrg19uk
« Reply #20 on: February 06, 2011, 06:57:13 PM »
Haha i could murder a beer numb the throbbing of my finger! ;D
I'll stock up before the next meet they sell loads of east european beers in a little shop round the corner :-p
Ive done most of it New plugs, new leads I haven't changed the cap or rotor yet or points.
 Carb had all new gaskets, I was thinking it may need tuning.
I may take a visit to dyno tune get them to rolling road even just for the video of it on the rollers ;-)
 :wave: :wave:
I'm gonna go for a run in it now so fingers crossed the oil light won't come on.
Neil gargaro
nrg19uk
« Reply #21 on: February 07, 2011, 12:49:28 PM »
well my drive was fun i started off from erith in kent thought i would go for a long coastal drive  8)
car was purring away at 55-60 until i hit the massive hill just after the medway bridge, the car was really stuggling in 4th so i dropped it down to third and pushed on, at the top of the hill i was greated by my  friend the oil light again this time just flickering so i got it upto the top of the hill and back upto 4th and carried on driving. The oil light went away and carried on to whitstable on the beach checked the engine over and i was suprised at the lack of heat coming from the engine it was running so much cooler. i thought i would check the electrics over as i was getting a little missfire going down the little village, one of the spark plug screw tops had come undone so i tightened them up and off i went along the coastal road  :D i have friends who lives in ramsgate so i headed that way stopping off along the harbour for a couple of pics
went to start and starter motor didnt wanna play, brand new starter playing up??? batts good whats going on so i thought i would bump start it and get it to my friends.
i kicked the gf out to push no luck! then three blokes walked up started taking pictures of the car, just so happened to be polish  ;D so in my best english polish accent got them to push
car came to a skid every time i engaged the clutch  >:(
 well that was it the polish guys had the car pushed over to the light, bonnet opened fiddling with the engine.
Neil gargaro
skelz
« Reply #22 on: February 07, 2011, 12:57:14 PM »
and what did they do ?
nrg19uk
« Reply #23 on: February 07, 2011, 01:19:35 PM »
I had to start a new msg as when im typing the page keeps jumping to the top of the text  :-
anyway, they pulled the dizzy cap off, dipstick out, couldnt see the ultra clean oil that was in there and thought the engine was seized.
once shaking there hands for there help off they went too the pub and i phoned my friend to bring there tool kit down, the starter lever was stuck open so i thought that was jammed in the fly wheel so i took the starter off minus a stripped bolt and a lobe and boy was it jammed! a couple of clumps with the hammer later it was out.  i taped the connections up and bumped started her and she was away  :P got her to my friends house and used a piece of wire to hold the connections from the starter together and taped them up out the way.
had a nice cuppa tea and set off for my home journey cruising at 55-60 with the gf worried if i stalled it she would have to push me hehehe
i managed todo 150/60miles on a full tank????
also  that if i dropped down to 3rd gear going up hill and sat at 35/40 the oil light wouldnt come on and i need to turn my idle up to stop the oil light coming on at the lights or stationary.
what have i learnt from this? take a half decent tool kit! and dont over tighten bolts.
« Last Edit: February 07, 2011, 04:09:18 PM by nrg19uk »
Neil gargaro
« Reply #24 on: February 07, 2011, 06:25:34 PM »
That is a great "blood & guts" motoring story with that all important ending , you got it back home  [-/
So well done but where do you go from here  ???
nrg19uk
« Reply #25 on: February 07, 2011, 07:04:46 PM »
I thought it went well apart from the starter  :) i cant wait for the summer now!
Now I've got too pull the engine Out I've brought some time sert type things and rethread the holes. You will like these rusty only downside is there 3 pound each you drill a 9mm hole and screw it straight in which cuts its own thread solely designed for aluminium and no complecated tools needed just a bolt and two nuts. I'm gonna take the starter back and hopefully they can swap the casing over for a fee
I've managed to snap the choke cable aswell  :-
Then I can get the carb tuned! Hopefully that will sort most of labouring issues or I will pull the gearbox apart and change the fourth cog.
On a positive note I went to ikea the other day and found a parcel shelf dumped in the carpark took it home and it fits perfectly :-p I don't know what car it's from
Neil gargaro
« Reply #26 on: February 07, 2011, 07:58:06 PM »
I saw those Time Sert kits on eBay last week when I was looking for some helicoil inserts and I thought at the time if they are the real business then they were a good buy , I think the kit was about £35 .
I am guessing that they are a crib on the original Keenserts that I came across many years ago. They are fitted pretty much as standard on race / rally cars but very expensive. If those ones you have are as good you got a good deal  :D
Mind you in the "dumped in the car park" department you are a bit of a lightweight as I went to Tesco this morning & someone had dumped a half size Strat look alike electric guitar in the bin. Got it sorted and now I am a "guitar hero" having fixed one last week as well so going down in a blaze of glory  ;D
« Reply #27 on: February 07, 2011, 10:11:41 PM »
150/160 on a tank isn't too bad, I run to about 120 when my reserve light comes on but then I'm running a Dellorto FZD carb.
Points do tend to jump about on the strobe, I've checked mine for play in the dizzy and found nothing much so figure it must just be how they are :P
Uphill I find I drop to about 50 on the motorway at the top of hills, can be a bugger when there is a big lorry behind... so 35/40 seems a bit too slow up hills.
I found mine with the electronic ignition was rubbish and overheated so went back to points but since found that she prefers to run firing on the arrow rather than the mark which makes me wonder if the mark on the pulley is in the right place :o
It's crazy should fire 10 degrees before tdc at idle and advance to 28 i think but it always seems to advance more than that :oops:
Who knows, I'll wait for summer to tinker more. Thinking of going back to basics, pulling the cam out for inspection for wear, checking timing although it's two marks so what more can it want :P and just work through it slowly.
Sounds like your starter is properly knackered as being engaged it'll eventually seize-up and probably cook itself. :(
nrg19uk
« Reply #28 on: February 08, 2011, 05:49:07 PM »
I pulled the engine out to have a look at the damage the starter has done today
It looked as if someone before had chemical fixed the bolt in too hold the starter!
So I got my new time sert things installed and bobs your uncle one fully working fiat for now :-)
 time serts are not the easier to fit you have to drill out a massive 10.5mm hole As for self threading they was a pig to start might be worth taping a thread first just to get it started, they are not gonna move now!  [-/
I think they are perfect for bigger fixings and stick with the helicoils for smaller stuff, one good thing is if my exhaust studs pull out I know that these babys are going back. I will post a picture up of the time serfs when I'm at the computer later
 :D
Neil gargaro
« Reply #29 on: February 08, 2011, 05:57:21 PM »
Neil , has your car got the bracket that supports the back of the stater motor fitted  ???
