Author Topic: bis lowering - rear shocks  (Read 2426 times)
FluxCo
  • 89 BIS
« on: December 18, 2010, 11:46:23 AM »
hello
i have been advised there isnt a complete lowering kt (springs and shocks front and back) available for the bis
i know i can use the kit for the aircools, but cant use the rear shocks, because they are different
is this true?
if not, where can i get a lowering kit for my bis?
thanks
FluxCo
  • 89 BIS
Re: bis lowering - rear shocks
« Reply #1 on: December 30, 2010, 09:58:50 PM »
since no one reply, i will post my findings
i have been told by a few people there arent any shorten rear dampers available for the bis
and i have found out that to lower a bis its common to:
front - use air cool rear shocks at the front reversed eyelet front springs
rear - chop a coil off the rear spring
« Reply #2 on: December 30, 2010, 11:08:19 PM »
The reverse eye springs are only made for 500's And the early 126's As i found out after buying one and fitting it :( and do not fit the later aircooled and bis as the main leaf is longer than the 500's. if you are a hands on guy here's a link to show you how its done with the standard spring, You don't need to reverse the eye just de-camber the leafs, doing it this way also retains the safety leaf :D
http://www.jalopyjournal.com/forum/showthread.php?t=90824
or have it de-cambered by a spring manufacturer if your not sure [-/
The rears coils can be chopped if the spring isn't tired, sits in the top and bottom cups and does not drop out with the standard shockers fitted [-/
gsxr126
« Reply #3 on: December 31, 2010, 12:23:42 AM »
Thats an awesome thread Pete. [-/
markymarc
« Reply #4 on: January 04, 2011, 07:15:35 PM »
Anyone know a company that can do this process on the front leaf spring in the east anglian area?
goombas
  • 126p 1992 650e
    • www.wirtualnygostyn.pl/racing
« Reply #5 on: January 05, 2011, 04:19:34 PM »
i will join your discusion
how to drop it on the ground
leafspring front few types of mods. zou have to go with it to a smith to get it flat for the height You want, original is 24 cm from ground in the middle that is highest point, mine is flatened to 15 cm and it drives ok, turnes ok, rubs a little bit the inside of the wheelarch while maximum turning thats good for lowering for racing some say zou have to giveone laef more while flatenig to give it more stiffness but it has to be lower to let drop more because it will be stiffer. with mine setting i can get to 2,5 degrees negative position of wheels for better grip while cornering. of course all depends on your smith and the leaf your working on, use only new originals or origilnas, zou will propobly try more than once till zour be happy, i tried twice and now third setting hopfullz will be the last one, about shocks like u said rear to front, and change oil in the rear shocks  for rear, or buy an avaible bilstain shocks kit for 126p, but for the city use just cut the spring and flat the leafspring dont need to change shocks
rear springs
it is commonto cut it by one turn of the spring, nothing happends with the wheel no rubing or hiting, but u have to remember that if you cut a spring it becomes softer so i used rubber spring spacers to make it stiffer and now i will mount modified shocks for rear and rear to front
...if good thought that frontwheeldrive is better we would ended up walking on hands...
