Hi Steve, I've been reserching this subject for a while now, there are no clear descriptions on the subject, as on here, everyone seems to go along different directions.
Rusty tells me the 500 website is like watching paint dry, so doubt there will be much wisdom from there, hence my dragging my feet with membership there.
From my research I have found the high performance engines used in the famous Abarth 595's could do a higher speed than the new Fiat 500 Abarth. I know, sounds like a load of old poo AGAIN from me but I think it was 125mph top speed for the old 595, and the new Abarth is quoted at 120mph...this is I think...not gospel truth as I have a memory like my 500's floor's ability to hold water. I do remember it was 5mph faster...with drum brakes!
Cranks were upgraded to a steel crank, no mention I have read anywhere specifies different bearings but roller bearings make sense in my opinion, how that is going to affect lubrication, you're cleverer than me so you'd probably be better able to answer that. The next must seems to be stronger conrods, I have seen Titanium rods!!! for a price...
They also fit lightened pistons and often drop one ring, less friction? seems a bit too racy for my every day wagon.
Lightened flywheel, some which look like a work of art, and much stronger famously red Abarth valve springs with obviously offset valve guides and bigger valves, bigger capacities up to 800cc with reinvocement plates fitted under the barrels. Apparently the 650 engine was reinforced with webs in the casting of the crankcase. Obviously cam is changed.
Webber 40 carb seems a popular choice on the higher spec cars. 1 to 1 ratio on the fan, higher compression ratio..it goes-on! Alot of Euros can be spent i remember something like 1600 euros for titanium rods! Even Titanium valve caps!
I'd love to find-out the exact spec of the old very fast 595's as it's give us a clear direction to go in as they've been there, done that, broken bits. I'll find the website tomorrow, I saved it for the steel crank.
They aren't cheap, but then you're serious about your car, I want one [-/
With the possibility of over 100mph from an air cooled, it's the reason I moved from BIS to air cooled! Might take me 10 years but I'll get there
