Author Topic: Bertone Fiat X 1/9 Alloys  (Read 4719 times)
« on: August 26, 2010, 06:51:46 PM »
Do you think these wheels will look good on a 126?
13", 98 PDC, 2 Offset
Re: Bertone Fiat X 1/9 Alloys
« Reply #1 on: August 26, 2010, 07:32:00 PM »
Yes, they look great on a 126.
ypsilon_lancar
« Reply #2 on: August 26, 2010, 08:47:29 PM »
These ones? Im also considering them if they are
ypsilon_lancar
« Reply #3 on: August 26, 2010, 11:28:24 PM »
Just bought some!  [-/
Hope they look ok! I suppose anything is better than the Polski branded hub caps!
Allan
« Reply #4 on: August 27, 2010, 03:20:30 AM »
Just be aware that the little hubcaps are not that well attached and seem to enjoy falling off.
« Reply #5 on: August 27, 2010, 07:09:20 PM »
Mine were missing  :D
Allan
« Reply #6 on: August 27, 2010, 09:24:30 PM »
Told you
« Reply #7 on: August 28, 2010, 09:52:22 AM »
be carefull as these wheels are made from carbon and that with age they get very brittle so if you have a wheel to kerb experience it could bugger a wheel easily, Jorge used to have these on his bis and refurbed look really good.
ypsilon_lancar
« Reply #8 on: September 03, 2010, 11:24:40 PM »
I have a very strange issue with them. I fitted the rear ones and all was well, look good even if they do exagerate the camber!!!
However the front drivers side wheel (its LHD) is set further forward than the other side! Its only slight but means the wheel rubs the front. I have no idea why its like this. Everything is in good condition (its not rusted out) and its not had an accident. Is this normal??
It looks like a drag car now with fat rear wheels and the narrow fronts!!!
« Reply #9 on: September 04, 2010, 10:59:35 AM »
what size tyres are on these rims?
ypsilon_lancar
« Reply #10 on: September 05, 2010, 08:19:17 PM »
Need to double check but im sure they were both the same
ypsilon_lancar
« Reply #11 on: September 06, 2010, 12:37:47 PM »
155 65 R13 , all four of them!  >:(
« Reply #12 on: September 06, 2010, 12:57:38 PM »
I ran that size on a lowered Aircooled 126 . I cant remember the make of tyres but one make cleared the front OK but the other did not so went on the rear  [-/
« Reply #13 on: September 06, 2010, 10:13:32 PM »
I had the same problems with mine (not X1/9 alloys). All four alloys are identical but my rear tyres are thicker than the front ones. I do not remember the specification of the tyres. I will have a look tomorrow.
« Reply #14 on: September 07, 2010, 11:43:12 AM »
I have a similar problem on my 500 where one side was rubbing on the front. I too have 13" 5J wheels. On the rear I have Pirelli 155/65 R13 tyres and i did have them on the front too, but i could only turn about 1/2 lock, so not ideal.
I have since been fitting Michelin 145/60 R13s to the front and keeping the 155/65s on the rear. It works a treat.
