Author Topic: Bertone Fiat X 1/9 Alloys  (Read 4720 times)
smallcox
Re: Bertone Fiat X 1/9 Alloys
« Reply #15 on: September 07, 2010, 04:11:24 PM »
The tooling alignment seems to be dodgy on the 126, mines an 80's model and i noticed where the gear linkage goes through the rear floor the tooling hole were 5mm out off alignment(offcentre)? This men't the nylon plug would not fit correctly and had to modified. Then moving around the car YES the front was mis-a-lined on assembly. I thought it was just mine but now can see this is not the case. the front wheel are slightly offset on the front and one is further forward than the other so this is normal. I did adjust and re-aline mine but took forever :oops:
It's a cheap production car 8)
ypsilon_lancar
« Reply #16 on: September 07, 2010, 08:03:24 PM »
Having owned many Lancia's (They used to just substitute parts when they ran out during production so a Delta would end up with Thema parts on it!!)  and knowing how accurate Fiat group build cars i thought it would be a standard 'feature'!
I will try some lower profile tyres on the front, i suppose it gives me chance to have the front wheels refurbed whilst they are not fitted, then i can swap and get the other two done!
« Reply #17 on: September 07, 2010, 08:10:44 PM »
it could be that the wheel geometry is slightly different on the front i used to own a golf mk1 cabriolet and these have a similar thing in that the front wheels are not in perfect alignment for a reason i do not understand.
« Reply #18 on: September 11, 2010, 02:35:02 PM »
Front:155/65R13 73T
Rear: 165/55R13 70H
What does the last three bits mean?
ypsilon_lancar
« Reply #19 on: September 11, 2010, 08:33:22 PM »
speed ratings i think
Allan
« Reply #20 on: September 12, 2010, 12:36:05 AM »
The number is a size code and the letter is the speed rating.
« Reply #21 on: September 12, 2010, 07:05:29 AM »
I always get a bit anxious when it comes to MoT time as the tire thickness of my 126 Bis is different in the front and rear. Are there cars were the standard (non-modified) front tire is different from the rear tire? Can the MoT people actually insist on putting back the original spec. wheels and tires? It went through MoT before though with these alloys and tires but I need to be armed with an answer, just in case.
edsaysyes
« Reply #22 on: September 12, 2010, 10:52:02 AM »
Yes the letter at the end is the speed rating so H I think is up to 130 mph Perhaps best to go for V which is over 130 Just in case you find a long downhill section on the road
ypsilon_lancar
« Reply #23 on: September 12, 2010, 08:54:39 PM »
The tyres just have to be the same on its common axle, so both rears the same and both front the same.
