Author Topic: New baby - big job ....  (Read 8802 times)
« on: July 27, 2010, 10:25:02 AM »
Was hoping to get it onto wheels, so my bike trailer isn't tie-up for months but wasn't to be.
Found some old 126 knuckles to put some front wheels on but the springs are missing for the rears.
Good bits are new panels fitted to floor, inner sills inner front wings and inner front panel.
Bad bits are doors and panels missing but friday i go collect all panels required for the job.
Bits still needed - 500 engine mount, 500 gear box mount, 500 rear seats as 126 ones dont fit, knuckles for the front as 126 hubs are bigger, starter bit to bolt onto gearbox(have two 126 starters so replace front bit) quarter light windows, voltage regulator, rear springs (think I have made a plan) , no doubt all available through the trade but any offers welcome ;)
« Last Edit: July 27, 2010, 10:46:51 AM by Darrell »
rmbruton
  • before
Re: New baby - big job ....
« Reply #1 on: July 27, 2010, 11:05:57 AM »
looks like alot of fun. good luck
« Reply #2 on: July 27, 2010, 11:44:35 AM »
 Looks like a lot of work :)
 Darrell I think I have got the engine mount as well. If you are looking for the original 500 type. It is still mounted on the back panel. I have a look, as I think I might have a starter too.
« Reply #3 on: July 29, 2010, 08:16:28 PM »
Don't forget to have fun while you're at it  [-/
« Reply #4 on: July 29, 2010, 09:53:21 PM »
New panels collected today 4 new inner wings, 4 new outer wings, front panel and doors [-/
Knackered now with all that excitement :oops:
« Reply #5 on: July 29, 2010, 10:02:03 PM »
you got any pics of the doors (once you've had some rest!!) might have to get a set at some poin, keen to see how they fit
« Reply #6 on: July 29, 2010, 11:24:10 PM »
Typically I couldnt help myself but put a bolt in the top hinge and bottom hinge to see what they look like. They look very good! They're heavy too! Heavier than I expected and seem really solid, wish my 126 doors were like them.
The sills look like they are in the wrong place and really need to sort out a better way to support the car this weekend before trying to fix any of the panels to the car, but Rome wasn't built in a day, just made me smile to see the cars 'face' for the first time :)
Pics of the trial fitting [-/
« Last Edit: July 30, 2010, 09:02:07 AM by Darrell »
« Reply #7 on: July 30, 2010, 07:58:35 PM »
That looks good Darrell :P Will it be ready for Retro Rides :D
« Reply #8 on: July 30, 2010, 09:28:53 PM »
Yeah mot next friday...NOT :P
The inner-inner wheel areches are giving me trouble, although they have been replaced, they seem like they are almost from another vehicle! :( Not sure what the solution will be but it looks like the angle grinder will be hard at work again.
Progress this evening, left door fitted and squared-up, all four wheel on so it's off the bike trailer.
Left rear wing cut-off ready for new one, Inner rear left wing tacked-on. Tryin to tack the inner front wing on and it's not playing ball at all!
Sills seem like they from another car too, well, the ones that came with the car so ordered new ones to replace them, should be with me for next weekend.
I figure if I can get a fairly sturdy frame (sills inner wings etc) I can turn it on it's side and start pulling underseal off.
Although it has new floor panels, it's not a pretty sight :oops:
« Reply #9 on: August 16, 2010, 09:21:55 AM »
A weekend of destroying my hearing, skin off nuckles etc has resulted in a very sturdy shell now.
Welded-up the inner bits to ensure she's solid and fitted the pannels. Primer on the door front way to check nothing is rubbing. Door etc needed fettling, just got to finnish-off the front now which I imagine to be another good weekend's work.
Think I'm sticking to 126 hubs on the front, will get adaptors for 500 rims with the intention of going disc brake but for now can use 126 drums on the front.
« Last Edit: August 16, 2010, 09:24:34 AM by Darrell »
« Reply #10 on: August 16, 2010, 11:41:39 AM »
I've promised Rusty to write down all the bits I still need.
Front headlamps complete
Front indicators complete
Corner lamps
Quarter light windows complete
Grill bit and wiskers
Adaptor plates 126 - 500 wheels
Wiring loom - the one in the car has been hacked to pieces
Front bumper bolts and spacers
dizzy cap, rotor and leads
Exhaust
1 x exhaust elbow
carpet
rear seats
front boot (bonnet seal)
front boot mat
master cylinder reservoir
master cylinder reservoir rubber mount
spare wheel
tyres x 5 (135-12)
rear suspension bushes x 4
front suspension spacers
brake pipes - all
accelorator cable - original one was cut! :(
big pipe to engine
small pipes from engine (heater)
steel bit of the ducting (heater)
hose up to dash
Rear lamps complete - ones on the car are cracked and bits missing
Rear soundproofing
Gearshift seal
Clutch cable
Wipers
shocks - miss match with car
Wishlist:
126 engine
126 box
disc brake conversion
126 gearshift complete (500 one does not have the antirattle spring)
That is all I can think of for now, More will become apparent as I go I'm sure.
Thanks to Lad for the rear panel and mount, gearbox mount and front suspension bits, a huge help!
kitten75
« Reply #11 on: August 16, 2010, 12:27:58 PM »
It's great seeing the transformation taking place!  I ordered a new engine for my 126 on Friday so my old engine (without valves and springs and god knows what else missing/broken!) is on offer if that would be of any help?  Obviously long way to courier it...but offer's there.
mhairi
« Reply #12 on: August 16, 2010, 03:47:23 PM »
Hi Mhari no just hang-on to the engine you have for a bit as you never know what you may need to complete yours.
Perhaps we can talk once it's up and running, I have a feeling I could use the crank and flywheel  [-/
I'm crazy enough to drive a 126 to Scotland too... :o
Arrival of a new toy today to complete the restoration  [-/ [-/
Pops (my dad) has advised me throughout the build and being he is a panel beater having worked for the likes or Rolls Royce I take his works as being from a guru.
So no more tacks...spots instead!! :oops:
RSPSTEVE
« Reply #13 on: August 16, 2010, 04:17:23 PM »
Nice one Darrell
Looking really good , good skills and the spot welder will be a god send ..lol
Steve
« Reply #14 on: August 16, 2010, 04:47:46 PM »
some great work here darrell I am watching with interest- wish I had a spot welder when doing my front end on alan..
keep it up!
wiring loom link if your pockets are deep- http://www.autosparks.co.uk/product_info.php?products_id=2556
