Various projects are moving along slowly but my 500L daily runner has been a bit off colour plus I wanted to try a minor upgrade on a standard 499ccs engine. Plan is to fit 126 camshaft , carb and exhaust along with the ported 500 head with enlarged inlet valves that I have just had done. Hopefully modest mods & an engine that breaths a little better.
I thought that the poor running may have been down to a blown head gasket or a valve but no evidence of that. Also engine has a real rattle so timing chain was suspect. This car has now done just over 100,000 miles so you are not sure what you will find
Took a picture to show the sag on the timing chain but it did not seem too bad , compared it with 2 other used ones & they looked very similar. Will dig out a new one later to compare.
The Haynes Manual says that removal of the cam is best done with the engine out as the followers can drop. So just lifted the followers and pushed a bag tie through the holes in the follower , can't drop now
More to come [-/
