Author Topic: bis with 135/80/12 tyres...  (Read 3818 times)
icbis
« on: June 24, 2010, 04:43:15 PM »
ok - the car i want to buy is spot-on; just one thing: it's a bis & it has 135/80/12 tyres! i measured the wheels: they are 13" across [external dimension] - is this something i should be concerned about? what problems could this cause? i really want this car - but the 12"-tyres are baffling me!
Re: bis with 135/80/12 tyres...
« Reply #1 on: June 24, 2010, 06:52:16 PM »
If you have measured the rim edge to edge in a straight line and its 13" there's no way the tyres are 12" they just won't fit.
Jan-in-UK
« Reply #2 on: June 24, 2010, 08:49:04 PM »
I was just about post the same :) hi hi hi, How did you come to the conclusion tyres are 12"??? If anything like it is pressed on a tyre you just made a mistake measuring it :D
www.fsoclub.co.uk
« Reply #3 on: June 24, 2010, 09:52:02 PM »
Even if they are 12" tyres the OD of the tyre they used on the 12" was the same as the 13".
The 13" tyres and rims are easily found. I have two in my shed, I'm sure there are other members with 13" kicking about :oops:
Allan
« Reply #4 on: June 24, 2010, 11:02:26 PM »
According to the owners manuals the a/c was fitted with a 135-12 (80 series) and the Bis with a 135/70-13. The height and circumference of both these sizes should be so similar as to not make any difference.
Allan
« Reply #5 on: June 24, 2010, 11:04:07 PM »
That is I should add until you start talking to Rusty's Uncle about disc brakes.
icbis
« Reply #6 on: June 25, 2010, 07:49:51 AM »
ok - thanks for that, guys; the tyres are stamped 135/80/r12 - but the rims i measured were definitely 13" across! should i still buy this car??!?
icbis
« Reply #7 on: June 25, 2010, 07:51:46 AM »
oh, btw: the tyres are all brand-new!  :P
« Reply #8 on: June 25, 2010, 09:24:33 AM »
If the bodywork and engine is good then the rims are a small detail no?
It's your call really :oops:
« Reply #9 on: June 25, 2010, 09:46:58 AM »
I would guess that you are measuring the rims incorrectly, it's the inner rim of the wheel that should be measured, see pic.
There's no harm using 12" wheels, so if the car is good go for it, you can always revert back to the 13" wheels at a later date.
Jan-in-UK
« Reply #10 on: June 25, 2010, 11:50:25 AM »
I might have some 13" steel rims from Cinquecento somewhere....
www.fsoclub.co.uk
icbis
« Reply #11 on: June 25, 2010, 12:18:28 PM »
ok - thanks again! yes, it would appear that i measured from the very external edge of the visible wheel. it's an awesome car, otherwise; i'm just baffled as to why someone would put 12"-wheels on it! any ideas on that? wouldn't it drive better with 13"-wheels?
« Last Edit: June 25, 2010, 04:12:35 PM by ChrisRLewis »
« Reply #12 on: June 25, 2010, 09:19:09 PM »
simple question look at the wheels are the holes in the wheels round or rectangular as the 13" are round and 12" rectangular (thats if they are fiat of course).
icbis
« Reply #13 on: June 25, 2010, 10:54:15 PM »
which holes - the hub-nut holes? they are definitely fiat wheels - they say 'fiat', on them! what will this answer to your question mean?
Jan-in-UK
« Reply #14 on: June 25, 2010, 11:03:17 PM »
bis13 meant these hole if i am right :D
These pictures are 12"
www.fsoclub.co.uk
