Author Topic: I think my engine is creating too much back-pressure :(  (Read 5239 times)
« on: June 20, 2010, 09:50:48 PM »
I might be wrong but I'm finding leaks here and there.
There must be alot of 'breathing' with two pistons going up and down.
Rings? or valve guides perhaps? :oops:
Re: I think my engine is creating too much back-pressure :(
« Reply #1 on: June 20, 2010, 10:26:55 PM »
didnt you change the rings ?
« Reply #2 on: June 20, 2010, 10:31:53 PM »
I did.
But she has been getting hot in the not too distant past, but this engine always seems to have had alot of backpressure....
It's done 48800 miles, same engine as numbers match i think.
Maybe I should just do rings again and new guides to be sure to be sure :oops:
« Reply #3 on: June 20, 2010, 10:36:03 PM »
I wonder how to isolate between valves/rings or test one or the other to know which is at fault?
« Reply #4 on: June 20, 2010, 11:21:41 PM »
Take the plugs out and check the colour on this link
http://www.verrill.com/moto/sellingguide/sparkplugs/plugcolorchart.htm
Allan
« Reply #5 on: June 21, 2010, 01:34:15 AM »
If you can find the equipement a cylinder leakage test will tell you where it's escaping. Used a lot for aircraft but also very effective in diagnosing car engines as well. They work by pressurising the cylinders one at a time. You can get a reading of the % of losss as well as listening at the carb for hissing (inlet valve) exhaust pipe (exhaust valve) and engine breather ( rings)
Allan
« Reply #6 on: June 21, 2010, 11:04:55 AM »
just an idea, are you using synthetic engine oil? if so its prone to cause leaks on old motors.
« Reply #7 on: June 21, 2010, 11:08:58 AM »
No I use mineral as I burnt my fingers with synthetic in my old Yamaha XS1100
I think that leakage tester is a mighty fine idea and have aquired one on e bay :oops:
« Reply #8 on: June 21, 2010, 12:34:32 PM »
Hey I like that cylinder leakage test idea , I did not know these things existed  :(
Reckon I will make my own one as I am not rich like Darrell  ;D
Going to crack the ceramic centre out of an old spark plug , set in a pipe extension with a nut on top and a normal car tyre valve then I can use a foot pump or small compressor on it  [-/
« Reply #10 on: June 21, 2010, 06:54:31 PM »
Where is the engine leaking oil ??? If the plugs are running clean then i don't think that is the problem. you would be able to tell if the rings were shot or the valve guides because on the overrun it would be pouring blue smoke out of the exhaust. it would also be difficult to start due to the lack of compression. If your engine does not have any of these symptoms you don't have a problem.
A couple of weeks ago you replaced the sump for the large capacity alloy one, did you check that the mating surface was flat and true some of the repro's are rubbish ??? you also had the timing chain cover off did you use new gaskets ???
As for the sneaky tool :D I have always managed with a piece of string ;D
« Reply #11 on: June 21, 2010, 07:22:27 PM »
All new gaskets were used on all the work done.
Doesn't seem difficult to start nor does there seem like any blue smoke at all.
My suspicions are due to a leak developing from the hole the dizzy sits in, took the dizzy out and replaced what looked like a perfectly good seal but did so anyhow.
Now it seems to leak from the oil cap.
I dunno but when I take the cap off when the engine is running, there seems to be more pressure in there than I think is right, but we'll see coz the sleaky tool will be serving two purposes ;)
How on earth do you use a piece of string to change guide seals/springs etc with the head still on?
 :oops:
« Reply #12 on: June 21, 2010, 07:52:34 PM »
They all produce allot of pressure in the sump with both pistons moving up and down together [-/ are you sure the seal is O.K.
The Piece of string ;D Take the rockers off, the spark plugs out, rotate the engine till the pistons are at bdc feed in the string, rotate the engine towards tdc, this compresses the string to the valves and holds them in place :P P.S. leave some of the string hanging out of the plug hole so you can pull the string out :D
« Reply #13 on: June 21, 2010, 09:47:03 PM »
What is making me suspicious is it only ever leaks when I run at 60 plus...
Those ally bits eg the extended rocker cover...the castings are terrible! I had to clean-up the casting alot and check for true with water paper on glass.
Anyhow, cannot do any harm to test as much as I can as the more I know the engine the better. I have to confess the BIS I had could do 80, never leaked, never overheated so the lesson seems to be that they're probably as good as each other, just has to be set-up right etc.
About your piece of string.....you sneaky...... [-/
One thing, the Dellorto has a simple trumpet on it.
When cold it will backfire through the carb a few times when starting from cold.
I'm wondering if this is a clue I have ignored.
On a good note, she doesn't pink/pre-ignite any more and seems to have loads more power with the Dellorto on it.
I did about 200 miles this weekend, one tank of about 15 litres did about 150 miles so dont seem to be any worse off with fuel consumption.
Torque seems more as some of the local hills I could only do 30 up, now she'll get to 40.
I still think it gets a bit too hot though as I had to run her with the engine lid open on the motorway, the tell tale for the excess heat is she starts to pre-ignite again, open the lid and it goes away.
Admittedly I'm running at 65 and I'm going to have a look at that gearbox, I might be running a BIS diff. I think that wouldn't help.
I thought I had a rubbish gearbox because it wines in fouth, enough to do my head-in but consulting the manual it seems end play might be at fault, so two jobs to do on the box makes it worth taking-out  :oops:
Allan
« Reply #14 on: June 21, 2010, 09:48:46 PM »
Hello again,
Darrell the hose you put up looks like an extension for a compression tester.
Rusty's uncle. You can make a leakage tester using an old spark plug and an Aro coupler. Knock the guts out of the plug and braise the Aro coupler onto it. Then apply compressed air at about 100 psi and listen as described. CAUTION. As soon as you plug in the air it will try and force the piston down so make sure you are on the compression stroke , piston at TDC. You will have to stop the engine from turning so car in gear brakes on. If you have any question give me a call.
Allan
