Author Topic: I think my engine is creating too much back-pressure :(  (Read 5239 times)
Allan
Re: I think my engine is creating too much back-pressure :(
« Reply #15 on: June 21, 2010, 10:01:18 PM »
Sorry Rusty's Uncle I forgot to add that the bought testers have a gauge on the that measures the % of loss. You zero the gauge before use and the plug it in. You need at least 100 psi to get a decent reading, remembering that most compression pressures are higher than that. If you are ever near a piston engined aircraft with the engine cowels of have a look as some engineers write the leakage on each cylinder for future reference.
Allan
« Reply #16 on: June 21, 2010, 10:03:53 PM »
I was thinking the hose would be a short-cut to what Rusty's doing :P
« Reply #17 on: June 21, 2010, 11:36:15 PM »
The only way it can spit back through the carb is if the inlet valve is slightly open when the spark plug sparks, What this means is assuming the camshaft timing is set correctly, that the ignition timing is out, If its too far advanced this would cause the engine to overheat.
If It was me having this problem I would take the 123 off and stick the standard distributor back in and see if the problem goes away :)
« Reply #18 on: June 22, 2010, 06:51:08 AM »
I just liked the idea of a simple device to put pressure into the cylinder and listen for leaks. Reminds me of tuning twin SU carbs by listening on a short piece of pipe at the inlet  ;D
« Reply #19 on: June 22, 2010, 08:19:29 AM »
Triumph TR4 and Land Rover with Rover 90 - 6  with twin carbs, listening to get the balance right? That sort of thing Rusty? My dad spent hours balancing those car's carbs  :oops:
The more I do, and the more I think and observe about the way the bug runs, the more I think 123 got something wrong.
I have resisted taking the 123 off, because I've really wanted to not have points issues, but will take the 123 off and test run her for a week :oops:
On another note, while sneaky tools are in mind.
Is there a way to hold/extract the cam followers whilst replacing the cam shaft, or is it a head off job only?
« Reply #20 on: June 22, 2010, 10:19:54 PM »
Its a head off job on the air-cooled because the push rod tube seats are located in the head :( on the bis you can fish out the tappets buy removing the rocker cover.
« Reply #21 on: June 23, 2010, 08:14:02 PM »
Now back to running poits...so we will see.. :oops:
« Reply #22 on: June 28, 2010, 03:17:19 PM »
Odd thing, never ever seems to pre-ignite with the points.....
I noticed the aluminium rocker cover has a very small hole for the breather, way smaller than the original tin rocker cover. I've made it alot bigger (9mm) but it still is alot smaller than the original breather was.
Thinking of whipping it off and trying to find a bigger holed fitting for the breather :oops:
Just don't know where to start looking for a bigger fitting....
« Reply #23 on: June 28, 2010, 06:40:06 PM »
Get down to the plumbers merchants I'm sure you could find some 15-22mm compression fittings that could be adapted and screwed in to the casting if you drill and tap the casting.
Is the engine overheating now you have taken the 123 ignition off ???
« Reply #24 on: June 28, 2010, 09:51:13 PM »
Hi Pete,
No doesn't seem to overheat at all. I did an uphill splat back from dropping Gilly off tonite, got to 70 and held it with no problems at all.
I'll definitely go see what kind of fittings they have that can be adapted. I have some BSP taps so should be able to drill and tap a bigger hole [-/
I think that's why i thought it was making too much back pressure...it blew it's dip stick out! :-X
« Reply #25 on: June 28, 2010, 10:16:57 PM »
i have blown out my dipstick a few times and also have an after market alloy rocker cover all i have done to combat this is change the dipstick rubber and wind a bit of tape around it so it fits tighter! you can also bend the dipstick so that it sits under the engine tin where the thermostat flap drops down and stops it popping out...
« Reply #26 on: July 04, 2010, 08:18:22 PM »
*update*
Took the car Southampton to Torquay area (Devon) and back today.
Uphill, downhill whatever, never a pre-ignition heard other than a deeper throaty-er noise from that gorgeous Dellorto and exhaust.
Some of the hills got quite scarey, one needed the car to be in second!
Oil stayed in the engine so I'm very happy.
It seems I am better suited to points than 123 ignition but am open to anyone teaching me what I'm doing wrong ....
The wiring for the 123 is still in place and now lives in the boot as a back-up.
Lost an exhaust bolt....scratched head on the side of the road and found one of the engine to gearbox bolts will work....better replace that.
I'm not looseing another exhaust bolt again so the locking plate bit i see on e bay will be purchased or wire-locking the nuts etc
As a point of interest I will be putting-up fuel consumption figures soon as I'd like comments , bear in mind I have a fairly heavy boot and try to sit at between 60 and 70.
Wouldnt be a bad idea to compare them to other air-coolers/bis's
The published figures...I dunno...
