Author Topic: Alternator??!  (Read 4764 times)
Korius
  • aircooled 126 ' 97
Alternator??!
« on: June 14, 2010, 10:47:09 AM »
Hello!  Last week i noticed that my battery have discharged.  Before month i took my battery to local battery shop for testing. It says that my battery is good. When engine is rotating, multimeter shows only 13V..( when turning on headlamps it showing only 12,6V)  Before two months it showed 14V-15V.. So its the problem in alternator?
Re: Alternator??!
« Reply #1 on: June 14, 2010, 01:15:03 PM »
Make sure your fan belt is not too loose  [-/
Korius
Re: Alternator??!
« Reply #2 on: June 16, 2010, 09:29:31 PM »
How its can be too loose? :D It is rotating alternator. :) or maybe when revs is bigger it slides an rotation is not effective.
How I need to check that it is not too loose?
P.S. Sorry for bad english. ;) I am 126 fan from Lithuania. (It is between Poland and Latvia) :D
Jan-in-UK
Re: Alternator??!
« Reply #3 on: June 17, 2010, 10:48:41 PM »
Mowisz po polsku?
www.fsoclub.co.uk
Korius
Re: Alternator??!
« Reply #4 on: June 21, 2010, 07:23:56 AM »
no.. I dont speek polish. ;)
Korius
Re: Alternator??!
« Reply #5 on: June 22, 2010, 09:04:26 AM »
I think there will be alternator brushes, becouse the battery light is lighting always on dashboard.
And the question is.. Can it be replaced? I need to take of alternator, or just unscrew few bolts ant take out bushes and replace?
Re: Alternator??!
« Reply #6 on: June 22, 2010, 10:36:55 PM »
Hi Korius.  Is it an alternator or dynamo (generator) ???
Can you post some Photos ;D
Korius
Re: Alternator??!
« Reply #7 on: June 23, 2010, 09:55:23 PM »
oh. What's the difference between alternator and dynamo?? ;D i don't know which is in my fiat?
Re: Alternator??!
« Reply #8 on: June 23, 2010, 11:46:45 PM »
If your Car is 1997 it will be an alternator, The fault can be 3 things, the Diode block, the voltage Regulator, or the Brushes.
These are all internal parts, the only way to get to them is to take the alternator/fan off,
I don't know the price of parts in Lithuania it may be cheaper to replace the alternator or take it to an auto electrical shop to be repaired. In Germany they sell the diode blocks for 40 euros.
Korius
Re: Alternator??!
« Reply #9 on: June 25, 2010, 02:56:25 PM »
Thanks for help. :) but I get to them without removing the alternator. You can take off the regulator, brushes and diode block without removing all alternator.
So, I took out the brushes. It looks to be OK with brushes.  But battery symbol is still lighting in dashboard. There is no charging on the battery (checked with multimeter, there was only 12.06 V, (same then engine is off)). But i checked voltage on alternator, there was 15,6 V.  So, I think the brushes are good. Regulator may be also good. And whats about diode block I dont know, becouse i dont have idea what is used for. Maybe the cable to the battery have broken somewhere. Which wire is going to the battery?
P.S. In Lithuania there is no one part shop of Fiat 126..  The only way is to ship from Poland. :)
« Last Edit: June 25, 2010, 03:24:48 PM by Korius »
Re: Alternator??!
« Reply #10 on: June 25, 2010, 06:49:48 PM »
The diode block converts the a/c=alternating current to d/c=direct current, if you have an output voltage on the thick maroon wire around +14.5 V the alternator should be O.K.
The thick maroon+ Wire goes from the alternator directly to the starter motor + it then goes direct to the battery + Terminal.
Korius
Re: Alternator??!
« Reply #11 on: June 26, 2010, 05:51:01 PM »
OK. I will check the voltage.  Can you tell me which wire is maroon in my photo? This which came out diode block and there is white rubber cap on it? Am I right?
And I want to get some advice, how can I check the wires from generator to the battery. :)
« Last Edit: June 26, 2010, 07:04:46 PM by Korius »
Re: Alternator??!
« Reply #12 on: June 26, 2010, 10:35:32 PM »
Hi Korius,
Disconnect the output wire from the alternator, Measure the voltage from the output wire down to earth it should read +12v battery voltage.
If it reads Zero there is a break in the cable to the starter motor.
If there is +12v battery voltage, The fault must be in the Alternator.
The diagram below is for the water cooled Bis, But it follows the same path.
Korius
Re: Alternator??!
« Reply #13 on: June 27, 2010, 12:19:55 PM »
Oh.. There is something mysterious with my Fiat..  I have disconected output  wire from alternator.. Checked with multimeter. It shows 12.06 V, like my battery.  So, the wiring from battery to alternator seems to be OK.
Then i have pushed the car to start the motor. And checked the voltage on the connected alternators output wire. It showed 15.6 V. But on the battery there was only around 12 V. And  battery icon was lighting on dashboard... So what the f*uk??! </*
 I don't have idea now what could be wrong with my alternator, battery, wiring and etc..  :D
 :lease:
Re: Alternator??!
« Reply #14 on: June 27, 2010, 10:18:41 PM »
The wire from the alternator-starter motor-battery is O.K. The fault must be in the alternator or voltage regulator. You could check if there is any current being drawn from the alternator by putting an ammeter in series between the output wire and the output connection on the alternator, Start the engine and switch on the headlights and see if it is pulling any current AMPS from the alternator.
This may help you understand how the alternator works.
http://www.youtube.com/watch?v=0VzvhfI4UpA
