Author Topic: Alternator??!  (Read 4764 times)
Korius
  • aircooled 126 ' 97
Re: Alternator??!
« Reply #15 on: June 28, 2010, 10:58:38 AM »
can I measure amps with regular multimeter?? How many amps  the alternator should be without headlamps? and with turned on headlamps?
Re: Alternator??!
« Reply #16 on: June 28, 2010, 06:32:28 PM »
The output from the alternator is 45 amps if your multimeter measures less than this you would blow the multimeter up.
I think we have established with your measurements that the alternator is faulty, if it was producing any power (AMPS) it would be charging the battery.
If it was mine i would start looking for a replacement.
There are some on Allegro http://www.moto.allegro.pl/listing.php/search?string=Fiat+126+alternator&from_showcat=1&category=0&change_view=1
By buying a replacement you will be able to get the 126 back on the road :P Then strip down the faulty unit to find out what the problem was ;D
Korius
Re: Alternator??!
« Reply #17 on: July 21, 2010, 09:37:24 AM »
SOLVED!!!! My Fiat is back on the road. :) The problem was in wiring. One wire between alternator and starter motor was under corosion. It was almost broken. :) So, i changed the wire, and the voltage now its OK. On alternator about 13.4-14.2V. On battery about 12.8 - 13.8 V.
I am very happy. ! Thanks everyone for help.
P.S I spent about 3 pounds to repair it.. and solved this problem about month..  </4  ;D
