Author Topic: Carbs ??!!  (Read 2919 times)
markymarc
Carbs ??!!
« on: May 27, 2010, 09:18:50 PM »
Hi guys,
I may have asked this before (humour me im getting old) Im keeping my 652cc engine fairly standard with a sports exhaust but would like to put a slightly bigger carb on it?
What would you guys recommend that has been done and to what cost, best supplier and would the standard air filter set-up be ok or may be some sort of induction kit/K&N filter be better?
Many thanks for any ideas
marc
gsxr126
Re: Carbs ??!!
« Reply #1 on: May 28, 2010, 12:18:05 AM »
There's a thread on here somewhere about fitment of a motorcycle carb, seem to remember it worked very well. Cant remember the thread name - i'm getting old too!
Re: Carbs ??!!
« Reply #2 on: May 28, 2010, 07:08:55 AM »
There are loads of carbs out there but the hard bit can be getting a suitable manifold unless you are a bit handy & can make your own. I did see a tuned engine a couple of years back that had an SU carb from a Morris Minor fitted & the guy said it worked very well  [-/
smallcox
Re: Carbs ??!!
« Reply #3 on: May 28, 2010, 07:29:53 AM »
I tyred a SU (hs4) which i still have but you need to make a manifold to fit it to, i used a right angle gas pipe the right size and welded flanges onto it.
This carb did work very well and had an k&n filter fitted to it, this run a 650 engine with a Gas flowed head and extractor manifold with inch and half exhaust.
Plus side it gave 35bhp on the rolling road with this set up but was dificult to start when warm as the pulse of two cyclinders caused the pump action in the carb to run rich on turn over but it did always start so [-/. mph was good to and drivability.
Ps you can mod the original carb as this is a good flowing carb for a standard engine (just because it standard equipment dont think its bad the only problem with the original carb it does not over fuel when you suddenly open the throttle.
Steve
markymarc
Re: Carbs ??!!
« Reply #4 on: May 29, 2010, 04:40:15 PM »
Cheers guys.....again possibly!!  I have seen the same carb for sale being classed as "opened up" (bigger jets i guess!?) And a polish guy at work said they used to adapt the standard carb.  Guess i need to find out more.
Thanks again
marc
Re: Carbs ??!!
« Reply #5 on: May 29, 2010, 06:27:15 PM »
I am sure that Steve is the guy to shed more light on this   [-/
Out of interest the original carb on the rare Fiat 500 Sport had an enlarged venturi on 26 IMB carb so I am guessing that the "opened up" carbs have probably had a similar modification carried out on the 28 IMB.
Given me more food for thought now  ::)
L DOT BIS
Re: Carbs ??!!
« Reply #6 on: June 02, 2010, 11:04:48 PM »
Im new to this site and just got my self a 126 but the TOP inlet flaps on the carb are  broken and the Springs gone?!! any one know where i can get it fixed???? ::)
Re: Carbs ??!!
« Reply #7 on: June 03, 2010, 09:42:41 PM »
you have a bis i take it from the name? have a look on ebay see whats on there carbs for the bis can be pricey first of all we need to know what type of carb you have weber or the polish copy? you can tell if its weber by the name being on the carb and if its a polish copy by some polish gobledegook on it (not trying to be patronising here). when you say the flaps have gone do you mean the butterflys? take a good close up photo and post it up.
Alfons1972
  • sorry for my bad english...
Re: Carbs ??!!
« Reply #8 on: June 11, 2010, 11:06:13 AM »
in Hamburg, Germany, there is www.ilmotore.de
ilmotore is a specialist for Fiat 500 and 126. And he opens the venturi of your 28 IMB to a bigger size. I think 30mm...
I unfortunately do not know, what that kind of carb costs...
Fiat 500 R
Fiat 500 giardiniera
