Author Topic: New wheels for my 91' 126 Bis...  (Read 9037 times)
TLT
« on: May 17, 2010, 08:49:22 PM »
Do y'all know if 5"x13 KN MINATOR (http://www.tyresave.co.uk/alloyskn.html) will fit directly on my 91' 126 bis ?!!! They're making them with the correct PCD.
Actualy, last week I was supposed to get some wheels from one chap 5.5"x13(http://www.leboncoin.fr/equipement_auto/106573220.htm?ca=12_s) & when we put them on, the front was perfect but the rear was touching the inside of the car body, we had to remove everything...
Original steel rims 4"x13" aren't available anymore and mines definitely need to be changed as they're in very bad shape...
What shoes can I put on my ride ?!!!! On top of this my budget is limited...
Thanks in advance and sorry for my english I'm a French chap
Re: New wheels for my 91' 126 Bis...
« Reply #1 on: May 17, 2010, 09:36:11 PM »
Hi TLT,
Welcome to the forum :D
I Had the same problem when i fitted my TSW wheels, I used a 5mm Spacer on the rears with the correct spigot rings and that sorted the problem out [-/
TLT
« Reply #2 on: May 17, 2010, 09:57:35 PM »
Thanks for your reply Pete, what size are your TSW wheels ?!!! Are Spacers mandatory with 5" wheels ?!!! Where did you get your spacers & which one should I get for my 126 Bis?!! Did someone try the KN MINATORS ?!!!
Another question connected :
Would those steel rims fit directly :
2450 rim for Cinquecento 06-95 - 03-98
Taille:  4.50Bx13 pouces 145/70R13
Entraxe: 4 trous x 98 mm 155/65R13
Déport: 36.5 mm
Bore: 58 mm
Less style but cost less & safety first, I drive my kids with it !
« Reply #3 on: May 17, 2010, 10:23:57 PM »
The TSW are 5.5j wide, the 5mm spacers are available here in the U.K. at most of the car shops.
The Cinquecento sporting wheels I think fit without a spacer ??? Maybe someone can confirm that there are quite a few 126's with them fitted, If so the cinq steel wheels should fit O.K. and be Safe.
smallcox
« Reply #4 on: May 18, 2010, 04:20:27 PM »
hi,
You do not mention size of tyre you are fitting, i fitted 185/55/13 to 13 inch wheels on 5.5J's and only just required slight attention to the front wheel arches to clear when turning lock to lock.
Steve
TLT
« Reply #5 on: May 18, 2010, 07:54:29 PM »
Actualy I've got 4 brand new Uniroyal Rally tyres size 135x70x13 (original size) I intend to fit on my new wheels...
« Last Edit: May 18, 2010, 08:10:54 PM by TLT »
« Reply #6 on: May 18, 2010, 08:12:49 PM »
Hi Steve, the tyre size on my 126 5.5j 13" wheels are 165x55x13 which seems to be the popular size for cinq sporting alloys.
TLT, Can you borrow a spare steel wheel from the cinq to see if it fits without rubbing ???
TLT
« Reply #7 on: May 18, 2010, 09:19:12 PM »
Unfortunately no.
here are the cinque steel rim specifications:
4.5"x13
PCD: 4 x 98
Offset: 30...38
Centre Bore: 58.0
126 bis wheels spec are :
The series dimensions for the 126 BIS tires are: 135/70 R 13 68 S
The rims are: 4.00Bx13 H2 Steel, bolt circle 4x98, ET 31,5
Wheel bolts: 4 pieces, bolt circle 98, thread: 12x1.25, torque: 7 kpm
Does it match ?!!!
KN MINATOR on a 126 bis anyone ?!!!
« Reply #8 on: May 18, 2010, 10:53:16 PM »
The ET (German) measurement = OffSet (English) they are the same measurement, The cinq steel wheel is 1/2" wider (13mm), if you measure from the inside wheel rim to the nearest part of the wheel arch where it can touch, take away 7mm and that should give you the clearance, Seeing that there are alot of 126 with sporting wheels 5.5jx13" you should not have a problem fitting the steelies, also the tyres you have will fit better on the 4.5 rims they would be stretched on the 5.5 rims.
TLT
« Reply #9 on: May 19, 2010, 08:05:09 PM »
Once again thanks for your reply Pete, we're coming to the end, it is very useful and therefore I know I can go for the cinquecento steel rims if I want to coz that should do it. Budget is around 200€.
If we talk about style, I'm still interested in the KN MINATOR 5"x13" ET20. Budget is 350€
The guy at Tyresave (Duncan) is very cool and replies to lots of my questions. Here's what told me:
"135.70.13 will certainly fit correctly on 5x13" wheels,
and 5x13" wheels at ET20 will fit correctly on the front and the rear.
The important figures are 4x13" ET31.5 (for the 126bis), which means the backspace is 95.5mm.
The Minator wheels are 5x13" ET20, which means the backspace is 96mm.
So you can see the clearance to the inner wheel arches is virtually the same.
So the wheel+tyres will not rub..."
Do you agree with all this ?!!! what about my 135x70x13 tyres on 5" wheels ? Will they be OK or streched too much ?!!! What is your advise ?!! What would you do ?...
Thanks for your help y'all !
« Reply #10 on: May 19, 2010, 09:20:58 PM »
Sounds good to me  :P If the experts say yes [-/
TLT
« Reply #11 on: May 19, 2010, 09:38:51 PM »
Who's the expert ?!!! I didn't catch your last post sorry....
Would you go for the KN minator ?!! 135x70x13 on 5" wheels OK ?!!!
« Reply #12 on: May 19, 2010, 10:04:12 PM »
Sorry, if the expert at tyresave (Duncan) says you can fit your new 135 tyres then that should be O.K. Just check the price they quoted includes shipping them over to France.
TLT
« Reply #13 on: May 19, 2010, 10:34:31 PM »
Ok, I'll let y'all know what I did & will send pics with the result.
Worm
« Reply #14 on: May 29, 2010, 03:00:06 PM »
Hi TLT
I am also in ther process of sourcing alloys for my 1983 126, i have been talking to Ducan at tyresave also. He recommended that 155.65.13 on the Minator 5"x13 would be the recommened size tyre. I think that the rims will protrude or at best be flush with the tyre if you fit 135.70.13 tyres. As the rim width is 5" (127mm) but the wheel width is nearer to 6" (152mm) therefore if you fit the 135.70.13 tyre 152-135=17mm divide by 2 = 8.5mm each side of rim, so allowing for a little extra on the tyre side wall form may not be the best size tyre to fit though, if you dont want to kerb the alloys.
