Author Topic: New wheels for my 91' 126 Bis...  (Read 9015 times)
Worm
Re: New wheels for my 91' 126 Bis...
« Reply #15 on: May 29, 2010, 03:07:50 PM »
PS
i also concluded with Ducan that the ET20 offset with the 5"x13 Minator due to my original steel wheel having an offset of around ET30 will actually have the same inner distance to the suspension stut all bar 4mm closer, and that with the 155.65.13 tyres the wheel and tyre will protrude the extra 1" from the arches.
My original steels are 12" though so i guess with the later bis they made them with 13" steels like you have.
A question for all those out there with 5 or 5.5" alloys, do they protrude your arches enough to affect by the MOT are there arch kits out there for the 126 to rectify this if need be??
« Reply #16 on: May 30, 2010, 11:00:54 AM »
As an alternative tyre size/choice, you could go with 145 60 R13s. I have Michelin Compact tyres of this size fitted tp the Cromodora 5j 13 rims on the front and 155 65 13s on the rears. I initially bought a set of 4 of the Pirelli 155 65s, but they rubbed a hell of a lot on the front so i had to go for something creating a smaller rolling diameter. I wouldn't want to go any narrower than the 145s as they are almost stretched as they are giving a very low profile.
Worm
« Reply #17 on: May 30, 2010, 04:06:11 PM »
Thanks for your reply. I think the 145s will be a little narrow to give my rims protection if i scrap a curb, i am thinkinng of 165 all round as i have 30-35 clearance to strut on front and 20-25mm clearance to underbody work/suspension on rears which having the 165 will offer more rim protection and hopefully not handle badly due to the extra width ::) The rolling radius will be near enough the same as the original wheels so hitting the arches vertically or turning hopefully wont be a problem ;)
Worm
« Reply #18 on: June 01, 2010, 03:53:33 PM »
hi,
You do not mention size of tyre you are fitting, i fitted 185/55/13 to 13 inch wheels on 5.5J's and only just required slight attention to the front wheel arches to clear when turning lock to lock.
Steve
After a bit of research i have concluded i could actually (if budget permits :o) get 5.5x15" Minator alloys with 175.40.15 tyres as the rolling radius will be the same and having 15" rather than 13" should bling the look a bit more. The strut cleanances look ok to.
Steve what sort of distance do your 185's offer the rim for protection is it about 10mm or more? Also what did you need to actually do to your arches to make lock to lock not rub, was it a whisker off the arch or grinder time ;D ;D?
gsxr126
« Reply #19 on: June 02, 2010, 03:58:02 AM »
Hi Worm,
Be careful with fifteens as they can be deceiving. I have 15x7 wheels on my project car with 195/45/15 Continentals. They fit on the hub and studs perfectly, and they dont foul on the shocks. The problem is however that i cant (or rather couldnt) turn the front wheels more than 1 inch as they foul on the front and rear of the wheels arches. I have cut heaps out of the front guards to get the lock to lock clearance right but you dont want to be doing that to a standardish car. 195s on a seven inch rim would be close to a 175 on a 5.5 inch rim in rolling diameter so i'm guessing the rolling diameter would be similar to mine. Have a look at my "hunt for wheels over" thread on here and you'll see what i mean.
If you can confirm that you get the same diameter as the thirteens i would go for it, but make sure its the same ( i will be very surprised if it is)
Dan
Worm
« Reply #20 on: June 02, 2010, 05:15:36 PM »
Blown that idea out the water as they dont make 175.40.15. Any wider and the rolling radius is all messed up and probably have to knock arches about too. Back to 13"
gsxr126
« Reply #21 on: June 02, 2010, 09:42:40 PM »
Thought so, from memory the smallest profile 15 tyre is a 45 series
TLT
« Reply #22 on: June 28, 2010, 09:57:33 PM »
My wheels are currenlty on the way... Actually I've already got 4 brand new 135x70x13 tyres & Duncan told me it would fit the wheels so I intend to try them on & I won't have to change the wheels for the MOT as well... Thanks I just hope it will be fine ... Do you mean it's risky to fit'em on ?!!!
Worm
« Reply #23 on: June 29, 2010, 03:03:38 PM »
Have to wait and see what they look like, they may end up being flush at best with the rims as the rims are 5" = 127mm plus about 10mm each side = 147mm. Depends how wide the actual 135 tyre is, may give you a few more mm's of rim protection. From discussions with Ducan i would have gone up to 155's as a minimum.
If you dont go near Kerbs it wont be an issue anyway.
Hope they look great. Post up a pic when fitted
« Last Edit: June 29, 2010, 03:23:18 PM by Worm »
TLT
« Reply #24 on: July 20, 2010, 09:28:43 PM »
Hello y'all !
Just to let y'all know I received dem wheels & they fit perfectly & straight on, I'd recommend dem to everyone who'd like to replace the original steel wheels. It looks good too & you can fit on the original tyre size in case you want the car to be ready for the MOT.
Thanks again for your help on this !
TT
Worm
« Reply #25 on: July 20, 2010, 09:54:38 PM »
Hello y'all !
TT
Excellent news, they look great ;)
