Author Topic: Turbo, Is it possible to do?  (Read 3472 times)
Jota69
« on: April 06, 2010, 11:18:14 AM »
I was thinking about installing a turbo onto the aircooled engine, Is this possible?
I was thinking of using a small t15 turbo, a small intercooler, amd install a fuel injector on the intake manifold with a pressure switch that will activate the injector once the car is on boost.
other things i will be installing are bigger valves, dellorto 40 dhla and maybe upgrade the engine to 700cc
Re: Turbo, Is it possible to do?
« Reply #1 on: April 06, 2010, 12:50:12 PM »
Anything is possible, just how long the engine will last is a worry.
I'd upgrade conrods (see Berni Motori) link i put up here.
might be worth asking the question of them :oops:
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« Reply #2 on: April 07, 2010, 01:27:07 PM »
i know john bitmead ( aka darkhorse ) . made a aircooled engine with a turbo etc using metro bits and gubbins .
i think it lasted , he sold it awhile ago though .
i suppose anythings possible , but i wouldnt bother modding a aircooled 126 eng, might aswell swop it out for something altogether bigger?
as darrell said, anything can be acheived .. i suspect youll need deep posckets though, and just remember to tell the insurance comp of your mods ..
Jota69
« Reply #3 on: April 07, 2010, 10:30:12 PM »
I just found this for sale in an Italian used parts website
http://www.subito.it/kit-artigianale-turbo-per-fiat-500r-126-catania-12012387.htm
I will try to call tomorrow to get more detais about it
gsxr126
RSPSTEVE
« Reply #5 on: April 22, 2010, 10:26:44 AM »
Wow ,
That seems too good to be true !
Nice looking peice of kit too.
Still lots of work to make it work though, strenghened bottom end , lower the compression massivley, find some sort of way to get the fuel in, probably could use the metro turbo hif 44 carb. megajolt for the mappable ignition .........
« Reply #6 on: April 23, 2010, 09:48:45 PM »
very nice but wrong 500?
gsxr126
« Reply #8 on: April 25, 2010, 02:02:49 AM »
Inflations a b#tch
Eklipze3k
« Reply #9 on: April 25, 2010, 08:46:32 AM »
Generic kits, seen exactly the same thing being sold for Cinq's, Sei's, Punto's, Saxo's, Corsa's etc etc. Definitely not "plug and play"
Jota69
« Reply #10 on: April 25, 2010, 01:01:49 PM »
Yes it's not plug and play but you get a lot of the parts needed to build your kit
smallcox
« Reply #11 on: May 13, 2010, 02:49:49 AM »
Hi, turbo charging these little 2 cyclinder engines is possible but require a lot of work to complete a reliable finished item. i have a gt15 garret installed on my 126 and it does give it a kick, but over boost it and your conrod say hello through the side off your block. if running standard rods dont go mad with the boost pressures as i did. set a 0-60 time off no less than 15secs and all should stay in one peice.
RSPSTEVE
« Reply #12 on: May 13, 2010, 07:51:58 AM »
Hi smallcox, where in Essex are you ?
Steve
