Thanks for your help guys. Decided to bite the bullet and have a go, that's the beauty of self employment!
Right, how hard can it be- a couple of bushes?
No access under the car so, 3 seats out, centre console out, seat belts out, carpet out, rear tunnel cover out, front tunnel cover out.
Jack car up, undo rear rod/flexi union bolt (10mm where you can see it, 13mm where you can't- live & learn!)
Undo gear stick bolts on the tunnel, withdraw gear rod. Job done! No bushes to be found where they should be, they're all broken up!
New bushes for me then! Could someone tell me where the springs go that come with the repair kit?
I didn't find any! Do you have some spare bushes Dave! Otherwise it's Ricambio, expensive I know but local to me.
R.
