Author Topic: DESPARATELY NEEDED: Steering column switch  (Read 2719 times)
doglog
« on: January 27, 2010, 08:57:49 PM »
I'm after a steering column switch with: 5 pin red connector, 6 pin white connector & 4 slot white connector.
I've bought two, one from Axel Gerstl and one from Ricambio and they're both wrong and neither stock the correct one. It's driving me mad!
I can't afford to keep buying them from Germany or Italy and posting them back because they're not right.
It's the last bit I need to pass the MOT and get on the road.
Please can anyone help?
« Last Edit: January 28, 2010, 03:46:11 PM by doglog »
Re: DESPARATELY NEEDED: Steering column switch
« Reply #1 on: January 28, 2010, 11:42:03 PM »
Would it be possible to post a photograph of the part you need?
doglog
« Reply #2 on: January 29, 2010, 11:15:37 AM »
These are the connectors
doglog
« Reply #3 on: January 29, 2010, 11:16:55 AM »
and this is the switch
« Reply #4 on: January 29, 2010, 12:22:20 PM »
So I am guessing that you have a late air cooled car . What was the problem with the original switch  ???
doglog
« Reply #5 on: January 29, 2010, 01:18:41 PM »
Thanks for your help mate.
It's an '85 126 Brown, It failed the MOT on dodgy lights (indicators come on with sidelights, headlights flash etc.)
I thought this was a bad earth somewhere, but apparently not. After hours of searching through spaghetti, I got an auto electrician to check it out who traced it it to the steering column switch. He is 100% certain that the switch is knackered. I ordered a replacement from Axel Gerstl which turned out to have the wrong connectors (all 4 pin). Ordered another from Ricambio with the correct connectors (not an original 126 part, I think 127 maybe) but the wires were in a different order so everything lit up like a xmas tree! Apparently there are 3 or 4 different configurations of switch for a 126 for reasons unbeknown to me and I can't seem to get my hands on the one I require. I emailed FiatClassic in Germany and apparently they have the correct one, but I refuse to pay the €85.50!! (without postage) they are asking for it. I'm now looking down the x19 route as apparently they are the same switch. I just can't afford to keep buying switches and returning them when they wrong ones arrive. HELP!
Si
« Reply #6 on: January 29, 2010, 01:39:15 PM »
Sounds like a bit of a mare & I am probably of no help . I dug an old one out of my shed but it is all 4 pin . THe only problem I ever had with these was when I fitted halogen bulbs without a relay to handle the power so the contacts got a bit melted. I learnt the hard way but your problem sounds a bit different  :oops:
« Reply #7 on: January 29, 2010, 02:03:41 PM »
 I could only say the same as Rusty. I have got a complete wiring loom in the garage, checked it out and it is only 4 pins(it is from a 77 car) Never realised that they are all different. What a nightmare, you`ve got there.
richk
« Reply #8 on: January 29, 2010, 04:46:48 PM »
Hi Si
Have you been able to find what the extra pins are for? Does your car have an electric screen wash?
Perhaps you could use a four pin type switch after changing some plugs and then use an accessory type switch under the dash if needed?
A pain in the backside I know but it's horrible to be beaten by a few wires!!!!!!!!
All the best.
« Reply #9 on: January 29, 2010, 05:29:20 PM »
I had to do something similar,
I ended up swapping the connectors to the fusebox.
It took a while as it involved putting a switch on at a time and trying each spade till you get the right one, but I had it done by lunch time and not had a problem since.
It's not the easiest solution, but its very low cost!!
Michael
« Reply #10 on: January 29, 2010, 06:37:46 PM »
Is your 126 a pull start ??? If it starts on the ignition switch that could account for the extra terminals, and may be fitted with the later type a/c or bis ignition switch.
