Here's the old bolt and the new bolt
new bolt is 10mm, slightly longer to pass through the old nut and then tighten up, also a sping washer and nyloc nut will be fitted to make sure it does not shake loose!
In ref to the original nut, our head technician at work says that the bolt has not been stripped but has at some point been loose and because of this the shaking of the engine has widened the grooves of the bolt and ruined it. Also the original bolt has a 1.25 pitch thread and, according to him, can support up to 4.5tonnes!
