Author Topic: Sudden oil leak  (Read 3506 times)
TheCartorialist
    • TheCartorialist
Sudden oil leak
« on: November 26, 2009, 11:28:19 PM »
Yowsers!
I got it in one piece the 1400 kms from Poland to Sthlm without major problems. I change the exhaust system and all of a sudden she's spraying oil over the entire engine bay. What the what?
When I changed the exhaust I also changed the oil. I put 2 litres of 15-40 in it. What could I possibly have done? At first I thought I had put too much oil in but later checked to find the correct amount is something closer to 2.35 litres. If it was too much oil, could I have damaged a gasket? The engine runs fine and starts right up and there are no weird sounds. It seems to be coming from the right side of the engine when looking at it.
I don't think it's the oil cap as that's brand new and doesn't show signs of leakage.
Anyone's got any idea? Thanks.
Re: Sudden oil leak
« Reply #1 on: November 27, 2009, 06:44:59 PM »
you say you replaced the exhaust if so have replaced all the bolts on the brackets as these holes go right through to the sump and if they come out will allow oil to be forced out, another place to look is around the rocker cover check that the gasket is not shot. is the breather pipe connected (from rocker cover to airfilter?), is the dipstick blowing out as it is too loose? has the oil filler cap lost its inner washer or become loose?
Re: Sudden oil leak
« Reply #2 on: November 27, 2009, 07:00:12 PM »
I'd have to agree with the exhaust bracket bolts being loose. As bis13 mentioned they go through into the sump (i know from experience because nearly all the oil was sprayed into the engine bay on mine! :) )
Jan-in-UK
Re: Sudden oil leak
« Reply #3 on: November 27, 2009, 07:57:35 PM »
When I was about 17 years old i didi kill one engine like that :) it was this age when you are too stupid (in my case) to stop and investigate smoke as long as car moves :) :) :) :)
I would say there is a problem after exhaust being changed.  [-/
www.fsoclub.co.uk
TheCartorialist
    • TheCartorialist
Re: Sudden oil leak
« Reply #4 on: November 28, 2009, 08:32:36 AM »
Bis13 and GTMaster - you two are absolutely right. There's a bolt missing. How wonderful that it could be so simple. I am exstatic with joy, like a little boy. Thank you, thank you, thank you!
Re: Sudden oil leak
« Reply #5 on: November 28, 2009, 10:28:58 AM »
no worries glad it was a simple fix just make sure the brackets are the correct type and that they sit right up to the engine any space will result in a missing bolt from the vibrations along with stress fractures in the brackets and then the exhaust itself.
TheCartorialist
    • TheCartorialist
Re: Sudden oil leak
« Reply #6 on: November 28, 2009, 05:57:34 PM »
It seems it doesn't matter whether something's the right type or not. Nothing fits as it's supposed to. It's like som drunk person has made the components while watching TV, listening to the radio, having a fag in one hand and a glass of vodka in the other, all at the same time.
But boy do I love this car. I have driven some serious wheels in my days but this is unbelievable. EVERYONE likes it. It puts smiles on peoples faces, adolecent teens that don't normally care about anything give the thumbs up, people come up and talk, cars honk, people wave. I freakin' love it!
Re: Sudden oil leak
« Reply #7 on: November 28, 2009, 10:12:33 PM »
welcome to the world of 126!!!
MADMALUCH
Re: Sudden oil leak
« Reply #8 on: February 19, 2010, 09:10:15 PM »
I have just got myself a 126 aircooled...how could i refuse it...it was free...!
I drove it from the Polish city of Poznan to my home in the north of Poland , about 100 miles , and had to chuck oil in it several times as the oil light kept coming on due to low oil....
When i eventually got it home , and had a look in the daylight , i see its dripping oil from the right hand side of the engine ( as you look at it ) just below the exhaust pipe...   The exhaust is also a bit louder than it should be , and it looks as though the rear of the two..? exhaust brackets might be absent..!   could these events be connected...?
Its my first 126 , and i would be gratefull for any clues where to look for the origin of this leak..can anyone tell me the places to look , and what gaskets or seals i might need...
Fortunatly its not a problem to get bits for these machines over here in Polska...
Sounds rough...i think its only running on two cylinders...?
Re: Sudden oil leak
« Reply #9 on: February 19, 2010, 09:35:46 PM »
 :) Polska that reminds me of my old stamp collecting days  [-/
Anyway if the studs have ripped out of the crankcase where the exhaust mount should be then you will be pumping out oil big time  :oops:
Pretty easy fix though if you have the gear  :)
MADMALUCH
Re: Sudden oil leak
« Reply #10 on: February 20, 2010, 07:13:26 PM »
Can you tell from this pic if there is a bracket missing...?   It looks to me like there should be something bolted in those two holes near to the rearmost exhaust pipe...?
Re: Sudden oil leak
« Reply #11 on: February 20, 2010, 07:28:05 PM »
Yes the exhast bracket is missing, there should be two holding the main silencer box to the engine.
MADMALUCH
Re: Sudden oil leak
« Reply #12 on: February 20, 2010, 07:56:41 PM »
Aha...so that could be the cause of my oil leak...?   although it seems to leak from near the front bracket , and its the rear one thats missing...?
I suppose the oil could be running along the bottom of the engine and dripping from another place...?
Re: Sudden oil leak
« Reply #13 on: February 20, 2010, 08:06:44 PM »
You are going to have to get your spanners out as it is not difficult to check . Plus the one bracket that is visable looks a bit strange to me . Can't be all bad as you got it home , must be due to that good luck knot from a girl guide shown in the top of the picture.  :D
MADMALUCH
Re: Sudden oil leak
« Reply #14 on: February 20, 2010, 08:46:38 PM »
It could be the front bracket has been bodged , this is Poland after all , and it may be the leak is from the front bracket after all...I will get myself a proper pair of brackets and bolts and do the job properly....
The nice bit of string on the rear was used to pull the little beast out of a ten foot snow drift...And then we had to push it up and down the street to start it....I am quite amazed it got me home actually...
