Well , the tempreture has at last risen above zero out here in the Polish forests , some of the ten foot drifts of snow have melted , so its time to have a poke at my little 126 and get it sorted...
As i said earlier i had what seems to be a major oil leak coming from around the front exhaust bracket , and the rear exhaust bracket is missing...
Rusty,s uncle said that the front exhaust bracket looks a little odd , but i don,t think its a bodge job , maybe the Polish cars have a different type of bracket,,?...does anyone know...?
Anyways , i am going shopping in the next few days to get whatever parts are needed to fix this oil leak..Can anyone tell me if there are some seals that go on these bolts through the exhaust brackets , i am thinking that a bolt alone won,t stop the oil leaking out , but i don,t know on that...Also , does the bracket bolt to the exhaust , or does it need welding to the exhaust...?
I would like to get all the bits i might need to cure this oil leak , so can anyone suggest any other possible reasons for this leak other than the missing bolts and brackets...should i replace the rocker cap or gasket..? Parts for these cars are cheap and readily available out here so i want to get all the bits i may need in one go..if i don,t need them this time i may in the future...Give me a clue somebody...?
