Author Topic: Tachometer  (Read 4401 times)
Aaron
Tachometer
« on: October 22, 2009, 04:31:33 AM »
Guys,
I've come across a potential alternative to the Harley Tachometer (which can be quite pricey) on eBay, the item number is 380114884159.
The price is 17GBP at the moment.
I've had quite a bit of back and forth with the seller trying to work out it's suitability, but ultimately it's a digital universal unit which is capable of reading a 2 cylinder 4 stroke engine.
I've purchased one to give it a go and I'll report once I've installed it, though this may take a while to get down to Australia.
Re: Tachometer
« Reply #1 on: October 22, 2009, 09:11:28 AM »
I bought an oil pressure gauge of the same make etc.
I had no luck with it, the readings seemed to depend on if I had the lights on or not, temperature of the engine, wind speed, atmospheric pressure, wife's mood.....and I've checked with a strait gauge and my engine seems to produce a very steady 40psi so I hope you have better luck with it and will be watching this space with interest :oops:
Aaron
Re: Tachometer
« Reply #2 on: October 22, 2009, 09:40:05 AM »
Yeah it can be a bit of the luck of the draw with these things.  Had similar things with tachos, voltmeters and the like.  Even really expensive brands jumping all over the show.  Anyways we'll see when it gets here. ;)
Aaron
Re: Tachometer
« Reply #3 on: July 10, 2010, 07:32:23 AM »
Digging up an old post...
Ive finally got around to fitting the above mentioned gauge as I've been slow in working out how to mount it.  I really couldn't find anything commercially I liked so ended up making my own out of PVC pipe and aluminium flat bar.
Darrell yep you're right, it's pretty much a random numbers generator.  It tried putting a Tach filter on it thinking maybe the wasted saprk coil was throwing too much power at it, and while this stabilised it at just off idle revs, it's still a random numbers generator from about 2000 indicated up.
So has anyone actually found a 52mm tacho that works with the 126?  I'd like to fill my holder hole with something, I do have a vacuum gauge which came out of the wreck but I'm buggered if I can find any takeoff points for vacuum on the motor.  Is there an oil temperature gauge that fits in say the dipstick hole like on the old VWs or something?
Re: Tachometer
« Reply #4 on: July 10, 2010, 09:25:42 AM »
I recon the 'abarth' alloy sump i bought and fitted is a clever piece of kit as it has an oil temperature sensor fitted in it.
Havn't got a gauge yet :oops:
But the principal is good because the oil temperature in the sump would be the place to measure it.
Possibly whip the sump off and weld a threaded socket to suit an oil temp. sensor?
Aaron
Re: Tachometer
« Reply #5 on: July 11, 2010, 09:41:12 AM »
How about replacing the sump plug with an oil temp sender?  I've just been reading that VW kombis have this.
Re: Tachometer
« Reply #6 on: July 11, 2010, 11:22:26 AM »
Cannot see why not. As long at the thread is the same  ;)
Aaron
Re: Tachometer
« Reply #7 on: July 11, 2010, 11:33:28 AM »
Wouldn't happen to know what the air cooled sump thread is by chance?  I see you found this ebay link previously which might offer a simple solution
http://cgi.ebay.com.au/Sump-Plug-Sensor-Adaptor-Oil-Temperature-Gauge-Sender-/370406252627?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item563deee053
Re: Tachometer
« Reply #8 on: July 11, 2010, 03:53:08 PM »
The sump plug is 22 mms diameter and the thread pitch looks to be 1.5 mms  [-/
Allan
Re: Tachometer
« Reply #9 on: July 12, 2010, 10:09:18 AM »
And it's tapered.
Aaron
Re: Tachometer
« Reply #10 on: July 15, 2010, 06:28:35 AM »
Back to the tachometer front, I'm going to try one of these Buell tachos.  It seems Buell / Harley have offloaded some of their old stocks as they can be had at much cheaper prices than when you mention 'Harley'.
One of the cheapest I've seen at the moment is here: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290442829152&viewitem=&sspagename=STRK%3AMEWAX%3AIT.  But the picture is pretty bad, other sellers have better pics but far higher prices.
It looks to be a pretty straight forward bit of wiring on them.  Black = earth, orange = 12V power & Pink = signal.
I will advise how I get on.
Aaron
Re: Tachometer
« Reply #11 on: August 15, 2010, 10:13:49 AM »
Well guys, the Buell Tachometer seems to work well with the dual spark Niki.  To see my install, look under my posting in the restoration section.
The only thing with the twins spark ones (and it might just be the Polish twin sparks) is that you really need a Tach filter otherwise the needle will jump around like crazy.  The filter I used was based upon this post on the Camaro forums (yeah you find solutions in the weirdest places.)
http://www.camaros.net/forums/showthread.php?t=173302&highlight=tach+filter
The needle is pretty much steady as a rock with this filter arrangement.  I used the spare outlet on the coil as the take-off point - maybe this is why I need a filter.  Total cost of the parts to me was about $3 for the electronic bits from Jaycar and $5 for the heat shrink.
Either way this is certainly cheaper than using something with the word Harley on it.
