Author Topic: Gearbox/ Clutch noise  (Read 4070 times)
« on: September 25, 2009, 11:43:50 AM »
On the Bis we have a kind of rumbling fron the gearbox, press the clutch and it goes away, move the gear stick around and it goes away, any one know what it may be?  It doesn't do it all the time just now and again.
« Last Edit: September 25, 2009, 11:46:18 AM by ciaoflyer »
Re: Gearbox/ Clutch noise
« Reply #1 on: September 29, 2009, 06:46:22 PM »
Any Ideas.......?
« Reply #2 on: September 29, 2009, 07:07:43 PM »
If the gearbox is still working OK then you have to suspect one of the bearings. Clutch release if you are lucky otherwise you may be looking at a major strip down. Is the oil level OK as I thought that after about two years of driving my car I would check the oil. It only took about half a pint or less but it made a lot of difference to the gear changing. There can also be issues if the box has been filled with the wrong oil.  [-/
« Reply #3 on: September 29, 2009, 08:27:48 PM »
Thanks, I will have a look this weekend!
« Reply #4 on: September 30, 2009, 09:33:23 AM »
I know this is a highly frequently debated area, but what oil have you chosen to sticky by in your gearbox?
« Reply #5 on: September 30, 2009, 09:56:16 AM »
 Below is a copy of a reply I posted to this same question on another forum. Looking back at all the stuff it looks like 20/50 mineral oil is quite suitable for the 126 box & non EP 90 gear oil for the 500 box  [-/
"I have seen this topic debated so many times on this & other forums & it always seems to throw up more questions than answers and leaves your head reeling. So yesterday I spent about an hour & a half trying to research the subject on the net. I have got 3 Haynes 126 manuals that all recomend different oils (no 20/50 though) , Haynes 500 manual, 500 handbook & 126 handbook, again all different. After all that time reading some interesting stuff about oil I seemed to come full circle with a web site telling me to use the very same oil that we are told not to use !
So today I rang Penrite Oil and explained in deapth the Fiat 500/126 thing re the gearbox. The guy was incredibly helpful & explained his thinking on the subject and came up with the recomendation of their Mild EP Gear Oil which you can check out on their site. Also discussed engine oil and he recomended HPR30 for a clean engine or if you have an oil filter fitted otherwise if you have an engine with a few miles on it the lower detergent Shelsley Lite. Seems this thing is a bit like rocket science after all !
I also managed to contact an old mate today who I know swears by a certain oil he uses in his small fleet of classic cars. He spent his working life in the trade & at the sharpe end so I have great faith in what he says and he uses lubricants from G-Max Chemical & Research of Sutton. They do not seem to have a web site but the contact number is on the web.
& I thought that it was the ESSO sign that meant happy motoring"  ::)
« Reply #6 on: October 03, 2009, 05:53:21 PM »
Can you still get the Fiat stuff as recommended in the Bis owners manual...
TUTELA ZC 90
« Reply #7 on: October 03, 2009, 07:14:36 PM »
yes from fiat i use that .
« Reply #8 on: October 04, 2009, 08:53:24 AM »
Is it expensive?
« Reply #9 on: October 04, 2009, 12:08:39 PM »
no where i get it its cheap actually but up your end i dont know
« Reply #10 on: October 20, 2009, 08:04:08 PM »
Oil ordered from Fiat in Nuneaton, Fiat in Leicester never heard of it so could not get!  Nuneaton knew stright away what I was omn about, two litres for £16!
« Reply #11 on: October 20, 2009, 08:15:46 PM »
jeez do you know that i pay only £1.70 a bottle (litre) .
« Reply #12 on: October 22, 2009, 11:16:34 AM »
Where do you get it from?
« Reply #13 on: October 22, 2009, 11:05:49 PM »
a little fiat dealer around the corner the mechanic is very old and he seems to like me popping in for bits and i think he basically makes the price up!
« Reply #14 on: October 23, 2009, 10:12:59 PM »
I find the FIAT oil TUTELA ZC 90 reduces gearbox whine, dont know why but in my opinion it does.  I get it from my local FIAT dealer in Falkirk.  No t as cheap as £1.70 a bottle.
