I have a BIS and I am a bit worried about the issue of overheating. There appears to be a consensus that the thermostat is one of the reasons why the BIS overheats. I think there is a downside to removing the thermostat. Its job is to block the flow of coolant to the radiator until the engine has warmed up. When the engine is cold, no coolant flows through the engine. Once the engine reaches its operating temperature (generally about 200 degrees F, 95 degrees C), the thermostat opens. By letting the engine warm up as quickly as possible, the thermostat reduces engine wear, deposits and emissions. I am a bit paranoid and concerned about this, so I constantly watch the temperature gauge. If the thermostat is stuck closed it should not take long for the needle to reach the red zone even when the fan automatically switches on. Another cause of overheating is insufficient coolant level. The coolant levels should also be monitored closely. There should be a warning light in the instrument panel indicating insufficient coolant level. The odd thing with the 126 BIS, it has no coolant bottle (with a max. and min. indicator inscribed on the bottle) like other cars, so I am a bit unsure how to top up the car with coolant. When I take the cap off from the rear hatch (left side), do I simply fill the thing up to the brim with water?
