Author Topic: removing the thermostat on my bis  (Read 5560 times)
Re: removing the thermostat on my bis
« Reply #15 on: November 25, 2009, 12:15:37 PM »
How many wires does the switch have on it?
« Reply #16 on: November 25, 2009, 03:53:43 PM »
tbh I cant remember how many wire it has might be 2 or 3- the cooling fan switching system has 2 switches iirc- the one to the right of the radiator is an on/off switch (this is the one acutually screwed into the radiator)  this then runs through the speed control switch (the afformentioned one in the bottom left of the shrowd) which then feeds/controls how much current is fed into into the cooling fan itself.
« Reply #17 on: November 27, 2009, 12:00:29 PM »
Two stage switch is number 4 on the diagram.
« Reply #18 on: November 28, 2009, 11:18:50 PM »
I looked it up at Axel Grestl. Could the part you are all referring to is the thermal circuit breaker for radiator fan motor?
« Reply #19 on: November 28, 2009, 11:22:06 PM »
I looked up Axel Gerstl. Could the part you are all referring to is the Thermal circuit breaker for radiator fan motor (1987 to 1992)
« Reply #20 on: November 29, 2009, 11:43:50 AM »
That looks like it!
« Reply #21 on: November 29, 2009, 05:55:37 PM »
Ciaoflyer,
Going back to relocating the thermostat to the cylinder head. Do you have a picture of your thermostat in its new location? I am asking because it may be something that I can perhaps try to relocate myself rather than buying the kit.
Many thanks,
« Reply #22 on: November 29, 2009, 08:13:41 PM »
Look at petes red Bis he has it fitted and it's here in the garage section
http://club126uk.co.uk/smf/index.php?action=garage;sa=view_vehicle;VID=4
(Hope you don't mind pete?)
