Author Topic: Will any 4x100 rimms fit 126p????? Found different informations...  (Read 10296 times)
Jan-in-UK
Does anybody can answer this question please? Thank you.
www.fsoclub.co.uk
Re: Will any 4x100 rimms fit 126p????? Found different informations...
« Reply #1 on: June 21, 2009, 10:20:13 PM »
wobble bolts will take up 2mm but you may have to watch out for offset on rims not made for fiats...
Eklipze3k
« Reply #2 on: June 21, 2009, 10:21:37 PM »
Wobbly/PCD correction bolts will allow you to fit 4x100 rims, all you really need to be aware of is the centre bore. If this is too big then you need spigot rings, too small and you either need hub adaptors or to get the wheel centres machined out. On the assumption that it is the same as most other FIAT's the centre bore SHOULD be 58mm.
Edit: And offset ofc ;)
Jan-in-UK
« Reply #3 on: June 21, 2009, 10:50:17 PM »
Can somebody explain me OFFSET please?  >:( I am not good in these english terms at all, in Poland I would undestand anything  :D
Where I can get these Wobbley/PCD bolts???
My 903cc project is almost finished but now i desire myself some 4x100 wheels  8) always some complications...
Thank you for your kind help.
www.fsoclub.co.uk
Jan-in-UK
« Reply #5 on: June 22, 2009, 09:25:26 PM »
Thanks a lot, it helped so much (To administrator: give them karma for it  :D please). Well, do you think 101,60mm is too much for this woobley bolts????
Found one amazing but I am not sure. If it is too big will stay with 100mm.
PS: He he - I gave them - wasnt aware i can do that  [-/ [-/ [-/ cheers guys.
www.fsoclub.co.uk
Eklipze3k
« Reply #6 on: June 22, 2009, 11:19:29 PM »
101.6 is waaaay too much, if you're really desparate to go for them hub adaptors will be needed. Personally I would stick to 4x100  [-/
Andi
« Reply #7 on: June 23, 2009, 05:26:18 AM »
My dude bought a SWAP from Poland, with a Punto-engine and BMW-rims. These do-it-yourselfer are so hardcore, they didn't use PCDs. They took a metal file and widened the holes in the rims...I got heebie-jeebies when i realised, that i drove 180km/h with this scrap heaps, before i found out about the quality of Polish craft... :-X
Jan-in-UK
« Reply #8 on: June 25, 2009, 04:38:30 PM »
Not funny at all. Some jerks are still there - to save some money thwy would do anything  >:(
But trust me - loads of things is changing in Poland for better last years. Good craftsmans are avaliable - you just need to pay enough for them As same in Germany is it?
I had my 903 engine fitted by a simple and very enthusiatic youg lad in south Poland. Simple construction, simple solutions but done honestly and well. Effect? After 4 years or racing it still works superb. Just Maluch needs some refreshing as it has some dinks, scratches and other nice things on it  :D
Just by teh way - what is the proper offset or fiat wheels? What is the widest size of rimms ant tires to go with maluch (I can extend wheel arches, itsn't a problem). Thanks.
www.fsoclub.co.uk
Jan-in-UK
« Reply #9 on: July 09, 2009, 09:03:10 PM »
Will rimms + tires 185/50/R14 fit to maluch??????
Offset and diameter is ok for 100%.
Jan
www.fsoclub.co.uk
« Reply #10 on: July 09, 2009, 09:40:59 PM »
not without modifications .
Jan-in-UK
« Reply #11 on: July 09, 2009, 10:05:48 PM »
Thank mate, what sort of modifications will be needed apart from widening wheel arches?
www.fsoclub.co.uk
Jan-in-UK
« Reply #13 on: July 10, 2009, 09:37:29 AM »
Thanks Andi, these mangels wheel on German ebay are really superb. Well, I bought my 14" already and they are on the way. So I will try to fit them and than see how much I will have to adjust wheel arches. I can always re-sell it after, qutie rare on Ebay in this size. If I would adjust speedo (not a problem) what sort of modifications I would have to do?
www.fsoclub.co.uk
Jan-in-UK
« Reply #14 on: July 11, 2009, 08:27:00 PM »
So I did try it today and i thought maybe it is worth to post it for others as it answers some questions people might have.
My rimms came over from Poland, these are quite rare 14" size Borbet with Abarth hubs on it. Looks great and in almost new condition. Fabulous. So off course I tried to fit them on having in mind all answers you gave me. And what do we have?
1. All four wheel arches would have to be extended about 1 - 1.3 inch.
2. On rear (with factory size coils) they fit superb and I could easily use it (with arches extended).
3. On front tires are a little bit to wide  :-X they are 185 and slightly wider than rimm itself. But it just blocks a little bit when fully turned to each side.
So my question is (after obviously I would extend arches) - is it possible to fit 175 or even 165 tires on 6J 14" wheels???? Maybe lower profile 40???
Does these tires excist - 175/40/14?? 165/50/14??
Looks great so I thought I could try to do something, there is just a little bit of more space needed and maybe without big modifications it would be ok. Please advice. Pictures below.
www.fsoclub.co.uk
