Author Topic: Will any 4x100 rimms fit 126p????? Found different informations...  (Read 10296 times)
Jan-in-UK
Re: Will any 4x100 rimms fit 126p????? Found different informations...
« Reply #16 on: July 11, 2009, 10:31:57 PM »
If I would find tyres like that - do you think Andi it will sort out the space problem?
Maybe would be easier to extend arches a little more and have some spacers??
www.fsoclub.co.uk
Andi
« Reply #17 on: July 11, 2009, 10:39:30 PM »
Honestly: Those big tires look ugly on your nice car! A kind of off-road. Hummer or stuff like that. Xzibit-pimp-my-ride-style. They try on big wheels, too, and they fail: http://www.softpedia.com/screenshots/Unofficial-Pimp-My-Ride_1.png And it doens't help, if you reduce tire pressure, as shown... [-/
The problem is the 14". There's little to no choise in tires. You should choose one from the two above, and adjust the speedo. Better solution would have been 13".
13" Borbet go for 50,-Euro in Ebay. (set of four)
« Last Edit: July 11, 2009, 10:48:04 PM by Andi »
« Reply #18 on: July 12, 2009, 12:45:41 PM »
i think the 10" fiat 500 style racing wheels look the best i am thinking of sorting some out . they lower the car as well as making them quicker on pulling away/sprinting okay the top end suffers for it but then its not such a big deal.
14" alloys make for much trouble to fit and like andi says the tyre choice is very limited and expensive. another option is to go for the 12" wider steeleys and fit 12" streetlegal yoko trackday tyres for that stick to the floor racer look.
Jan-in-UK
« Reply #19 on: July 12, 2009, 12:50:51 PM »
Yep, you all right brothers. Mine 14" looks lovely but not for my fiat. Already gone to Ebay  :P
When sold will look up somenthing else, these mangels Andi showed me looks really tasty...
www.fsoclub.co.uk
Jan-in-UK
« Reply #21 on: July 12, 2009, 03:24:57 PM »
Ok, choice was made - I want to have 13" what so ever. Iknow all about rimms not (tnak you all)
So please tell me, what is the biggest possible size of tyre for 13" - I want them to fit to my orange without modifications.
Is it possible? If yes, please give me the size and i will go on hunting Poland/UK/Germany. I would apreciate.
www.fsoclub.co.uk
Jan-in-UK
« Reply #23 on: July 13, 2009, 08:08:10 PM »
I found some nice ATS's here and there, 13" of course. But all of them have centre bore 57,1mm....
Is it ok? I thought someone here said it should be 58mm. Please advice.
www.fsoclub.co.uk
Eklipze3k
« Reply #24 on: July 13, 2009, 08:20:05 PM »
57.1 is VW fitment, 58.1 is standard FIAT fitment. Can't imagine it'd cost too much to get them enlarged at a machine shop though
Jan-in-UK
« Reply #25 on: July 13, 2009, 08:44:08 PM »
Does anybody know any place close to London/Slough/Maidenhead they could do it for me? Sorry but my limited knowledge of english doesn't allow me to find anything on internet. How to look for it? What should I type in searche engine?
www.fsoclub.co.uk
« Reply #26 on: July 13, 2009, 10:10:57 PM »
you need to find a local engineering workshop.
Maddog
« Reply #27 on: July 14, 2009, 01:30:35 AM »
if you want to know what sizes are actually available then check camskill
http://www.camskill.co.uk/products.php?plid=m4b0s0p0
and for tyre size calculator
http://www.miata.net/garage/tirecalc.html
the reason the car looks jacked up is due to the sidewall to arch gap ratio, if you fit a larger rim and lower profile tyre, then you need to lower the car or it looks stupid, yours looks particularly bad at the back due to the tyre being flat and the swingarm kicking under.
if you fit 5.5j rims then they are going to stick out a bit, unless you go for a larger offset, ET45 ish. but then they may rub on inner arch/swingarms. 165 tyres are the widest you will get under there without hammering out the arches, even then they may touch the arches over bumps.
 If I had a car as original as yours then I'd stick with 155/65/13 on 5j rims ET32-35
« Reply #28 on: July 14, 2009, 06:13:36 AM »
There are plenty of Fiat/Alfa/lancia that will all fit, it would make life much easier :-)
I Bought these the other day.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=230352926444
At that price a refurb is worthy doing and they will still be cheap :-)
