Author Topic: TYRES!!!  (Read 7944 times)
puck304
TYRES!!!
« on: April 22, 2009, 09:19:22 PM »
Hi, does anyone out there know where to source 126 tyres from?
Mine are 135 65 13's and are proving hard to come by.... </*
Eklipze3k
Re: TYRES!!!
« Reply #1 on: April 22, 2009, 09:34:23 PM »
Do you know what width your wheels are?
I've had a hunt and can't find that size anywhere but at a guess 145/60r13's would fit too, and these are available on blackcircles for £60.10 a corner
Re: TYRES!!!
« Reply #2 on: April 22, 2009, 09:49:56 PM »
that is an odd size?
what year and model is your 126 and does it have standard steel wheels?
Re: TYRES!!!
« Reply #3 on: April 22, 2009, 10:22:49 PM »
The standard size should be 135/70/13 on the bis, you should be able to find them locally from any tyre shop, here's some on the net.  http://www.mytyres.co.uk/
puck304
Re: TYRES!!!
« Reply #4 on: April 22, 2009, 10:46:41 PM »
Hi, and thanks for the replies  [-/ , my 126 is a 1984 aircooled, and those are the tyres that are on there, which were what the car came with. My haynes just says 135 12, and the wheels to be 4.00 x 12 in. I assume the wheels are all originals, it came with a few spares, and the tyres on those are the same too.
Re: TYRES!!!
« Reply #5 on: April 22, 2009, 10:48:23 PM »
the original 12" were 135*80*12 i believe, and 135*70*13 were the standard for a bis, although i used 145*70*13 with no problem...
Re: TYRES!!!
« Reply #6 on: April 23, 2009, 08:27:33 AM »
take a pic of your wheels so we can see if they are original fiat/fsm steels as it sounds like you have had wheel swop somewhere as you should be on 12"s if they are 13"s they might be from a different marque?
tcosy
Re: TYRES!!!
« Reply #7 on: April 24, 2009, 08:42:19 AM »
I have 4 135/70x13's that are on my BIS that i am restoring, they won't be going back on as i will be fitting alloys and wider lower profile tyres, two are in very good nick. If you want to swap them with yours as long as they have some tread thats fine by me. Complete wheel/tyre swap that is. £5/each. I can find out the exact brand/tread depth on Sunday. The car is in Nuneaton. Cheers
puck304
Re: TYRES!!!
« Reply #8 on: April 26, 2009, 09:35:58 PM »
I'm having problems trying to upload compressed pictures, so this may have repeated a few times....
I must've been blind on the original post...my tyres sizes say 135*12*65 NOT 135*13*65...
I measured a wheel's diameter and it is 13".
Are these not the correct wheels then? Are these from a BIS?
These are the wheels the previous owner had on.
Cheers again
puck304
Re: TYRES!!!
« Reply #9 on: April 26, 2009, 11:32:27 PM »
well they are the original 12" aircooled steelies so its just some bizarre tyre size you have on them just replace them with the original 12" size they are cheap.
Re: TYRES!!!
« Reply #10 on: April 26, 2009, 11:47:24 PM »
As Mick said your looking for 135x80x12 which is a standard profile, on the link Mytires there about 20 each but any tire company should be able to supply them.
Re: TYRES!!!
« Reply #11 on: April 27, 2009, 09:23:38 AM »
Agree with Mick  [-/ can't agree with Pete  :o Yes they are the standard steel 12" wheels , you seem to have lost your hubcaps by the way.
Puck , in your reading of the tyre size those smaller numbers at the end are nothing to do with the size. Standard tyres would normaly be marked 135 12 or 135 R 12.
That means 135mms tyre width with a 12 inch diameter rim. If you have an R there that means Radial Tyre but the fact that the tyre width is given in mms also tells you it is a radial tyre.
Interesting that tyre sizes the world over are given in metric for width and imperial for rim diameter . That is a bit of a throwback to when we had one of the best motor industries in the world & called the shots. Prior to radial tyres we had cross ply tyres which were in imperial so a 5.20 x 14 tyre would be a cross ply 5.2 inches wide for a 14" rim.
Most modern car tyres now have a profile rating which is the height of the tyre section expressed as a percentage of the width. So a 135 80 12 tyre would have a section height 80% of 135mms and would in effect be a low profile tyre with a smaller overall diameter so this is where I disagree with Pete about the correct size for the 126 rims. If you did get that size tyre then you would gear your car down , lower the top speed,
improve acceleration & your speedo would over read.  :oops:
There are other letters & numbers especialy on some of the more hybred tyres but I have probably confused you enough already so I had better shut up now  :)
puck304
Re: TYRES!!!
« Reply #12 on: April 27, 2009, 11:12:59 AM »
So you think they are 12" ? What is the 13" diameter I measured then?
And what size tyres do I need?
Re: TYRES!!!
« Reply #13 on: April 27, 2009, 11:45:53 AM »
Bah, dont listen to theese guys, they overcomplicate things.... lets put it in simple terms. What you got there are standard aitcooled tires, judging by the rim model and by the tire format which IS 135/80/12. so go and buy an identical set, they should be fairly easy to come by.
the tire format is what i circled in the photo, the other numbers have nothing to do with it, just like the others said...
@Rustys uncle; what do you mean 135*80*12 is a low profile tire? the hight of this tire is 108mm, where my 155/65/13 have a height of 100 mms... i wouldnt call that low profile...
o/t. i didnt know Goodyear made tires that small...
« Last Edit: April 27, 2009, 11:47:58 AM by Gordan »
Re: TYRES!!!
« Reply #14 on: April 27, 2009, 11:56:02 AM »
The bit you measured was the outside diameter of the steel rim but the tyre size is measured at what is known as the bead on the tyre, ie the inner face which is a close fit on the rim and gives you the seal that you need on tubeless tyres  [-/
