Author Topic: Sort of Sorting Sortie  (Read 5255 times)
« on: April 20, 2009, 06:34:49 PM »
I felt that I needed to give my little car a bit of a shakedown to see how the little beast stood up to a long run , it is a 1972 bashed up left hand drive Fiat 500L which has been on the road in Italy (28 years) then London before I got it about 18 months ago & despite the unreliabilty of the electrics I managed to keep it going until around Christmas I fitted the 123 electronic ignition which seems to have overcome the problem. So I had been going out on increasingly longer runs including a memorable 2 1/2 hour run out in the deep snow . Inspired by some stuff on the 500 forum , check this one out -
http://www.next-horizon.org/
I felt like a bit of a lightweight  ::) & decided to go to a mates party down in deepest Cornwall in the little motor. 1st highlight was overtaking an Audi R8 on the M4 , he was no match for my 499ccs of raw power  :D
All went well down to deepest Dorset when I had to pull in for fuel. Pulling away I had trouble with the gear change . The clutch pedal was near the floor . I know from experience that the adjusting nuts can work loose & slacken the clutch so I managed to bump the nearside wheels onto a kerb in Portesham , adjust the clutch & it was back on the road again but gearchange did not seem too happy & a note for you guys running dynamos . The large pin that secures the dynamo clamp band was working its way out & I could not push it back. Thought I had better skip Lyme Regis & drove straight on to Honiton where I spotted the matt green 126 mentioned elsewhere. Got the car up on a ramp at a mates place for more clutch adjustment & sorted the dynamo clamp & pin. Had to take my hosts out for a ride then a late night before I got back on the road in the morning.
The accelerator pedal went into a world of its own as I got on the M5 heading into Exeter , managed to get into the services there . The throttle return spring had broken , I guess worn through on the mount , worth checking if your car has done some miles. Anyway you can bend out another coil withe aid of pliers & its back on the road again. Heading down the A30 I saw the sign for Bude , totaly out of my way but had to be done . Sun shone , roof back & the mildly sporty exhaust purred like a kitten on that great stretch of road. Swung into the main drag at Bude & realised that the clutch pedal was on the floor & the car was creeping forward in the traffic. Fortunately I know the town & managed to squeeze up the inside of the traffic into the Summerlease beach car park . Bumped the nearside up onto the sandy bank for more clutch adjusting. By now I had no idea what the hell was going on with the clutch but I fitted an extra lock nut on the lock nut just in case . The work was slightly hampered by all the passers by , young & old , who wanted to chat about the car but I was soon on the road again . A brief stop at Widemouth Bay beach which is kind of a spiritual home for cool motors , especialy aircooled but mainly VW so had to get the Fiat in there & got the thumbs up (think they were thumbs  :- ) from some of the VW Camper guys then it was back on the road & another bit I was looking forward to , The Atlantic Highway that swings down that north coast  8) . Made it down to St Austell & partyed long & hard  :beer:. A quick kip then it was the return journey. Gear changing was difficult  so decided to take main roads & the motorway to keep the number of gear changes to a minimum. Turned out to be a 7 hour flat out journey with a 15 min stop for breakfast & another fuel stop. 55 mpg which is what it says on the tin for a Fiat 500 , over 594 miles & it was 55 hours from door to door
 :wave:
Looks like it is an engine out job as the clutch is totaly screwed  :oops:
But it was worth it ! **-
Re: Sort of Sorting Sortie
« Reply #1 on: April 20, 2009, 06:46:11 PM »
So no problems then, just a smooth run.
Be honest it was tons more fun than taking the Rolls Royce.
Great Story.
« Reply #2 on: April 20, 2009, 06:52:04 PM »
nice write up thanks for sharing, Im off bodmin in a few weeks for RTTS and R&R for a week (sadly not in the fiat or any thing cool)
« Reply #3 on: April 21, 2009, 04:38:48 PM »
I now manage to stand upright after the journey home as I felt like a plastic figure from a toy car for about a day of so with body frozen into full throttle driving position  >:(
The clutch thing is a bit of a mystery as the pedal is about 2 inches lower than it should be, cable very taught but does not want to disengage. Only had time to remove the lower flywheel cover so far thinking that some bits might fall out but nothing so looks like it will have to come out  :(
« Reply #4 on: April 21, 2009, 11:05:13 PM »
 Sounds like you had great fun. Good story [-/
 I can`t believe you are still running the 499cc engine...
 As to the clutch, it sounds weird. Do you think the thrust bearing could have got stuck ??? Say if some reason the securing clips came out... No idea...
« Reply #5 on: April 21, 2009, 11:18:14 PM »
thats what i think has happened as well the clips arent the best way to fix the bearing in as they are rubbish
« Reply #6 on: May 05, 2009, 03:29:07 PM »
I had it once where the thrust bearing kind of made a groove in the thrust plate, eventually there was no metal left on the fingers and the thrust bearing pushed-through the fingers..it was weird :oops:
« Reply #7 on: May 05, 2009, 04:20:51 PM »
Ended up taking the engine out last week . The clutch cable was starting to break up inside the short bit of outer cable which could account for the problems but the release bearing did not feel quite right with the tension off the cable. Turned out to be OK but it was not a type I had seen before. Whacked in a new clutch & cable. Got it all back together last Friday and the clutch is now as light as a feather. The pressure assembly face was more worn than any I had seen before (about 0.020" groove) & the tension in the cable had bent the tube that the cable emerges from by the pedal down towards the floor so the pedal could not return to its proper height. For reasons I cannot work out the engine/gearbox assembly is sitting about 2cms too far forward causing the clutch cable to kink a bit more than it should thus aggrevating the wear on the cable.
I had a brand new Bis that ate clutches & got through 4 in 3 years for some reason & I have had pressure assemblies where the groove in those fingers has got very deep.
After one engine & box out job on my test run around the block I lost the clutch and the bolt that secures the clutch bearing release fork to the actuating arm had sheared off so had to take the whole lot out again to sort it  >:(
« Reply #8 on: May 07, 2009, 07:25:10 PM »
Done a few runs since the car went back together & had a couple of odd things. Although I only changed the clutch on the first run the engine seemed to get very hot quite quick & when I switched it off I got the old pre-ignition/running on thing for the first time ever. Then on subsequent runs that never happened but once warmed up the car stalled on tickover which was a pain as it was running as sweet as a nut before I took it out.  >:( So I kept using the car thinking I was looking at the whole ignition & carb strip down in the near future.
Did I do that  </ Naaaaargh ! Took a trip out to the longest stretch of slightly downhill dual carriageway that I knew & gave it a total max full throttle blast , net result when I got back on a minor road was a sweet running motor   :arty:
« Reply #9 on: November 16, 2009, 09:02:29 PM »
Hello. How is the 123 electronic ignition? I am interested in intalling one but was not sure if it was reliable. The chaps at Proietti swear by them. Has it been trouble free since you installed it in April this year?
« Reply #10 on: November 18, 2009, 05:05:42 PM »
Hi , I have actualy been running the 123 for about a year now . When I got my car I changed and checked everything on the ignition & fuel system , some items several times but it still kept on breaking down over about 15 months. I fitted the 123 & have never looked back. I know that a number of guys on here have bitten the bullet cost wise & been running the system for a lot longer than I have. I have only ever heard of one guy who had problems but it sounded like he fitted it badly & somehow managed to break his distributor. If you are thinking long term & reliability then I think it is the way to go. My preferred option is to just fit the cap to a half decent or better distributor & pick up a twin spark coil. Once fitted there is very little load on the distributor bearings as there is no cam action on the points.. You may well get a better price from the official distributor as listed on the 123 web site. Especialy if you say you have heard about it on the 126 forum  [-/
« Reply #11 on: November 18, 2009, 11:49:14 PM »
Looks like I will also bite the bullet and go for the 123 electronic ignition coil but probably next year (Christmas is quite soon). Presume that the twin spark coil you are referring to is the double coil also being sold at the 123ignition.nl website. Does this work for a 126 BIS?
« Reply #12 on: November 27, 2009, 11:14:49 PM »
I looked at the package being sold by Ricambio and others. Presumably, I do not need the whole package as I already have an electronic coil on my BIS, is that correct or do I use the coil that comes with the electronic distributor as it is compatible? Is there anything else i need? They might insist on selling the whole package, even if I do not need it.
« Reply #13 on: November 28, 2009, 10:09:10 AM »
I don't think the 123 will work on the Bis, I thought it was just for aircooleds?
« Reply #14 on: November 29, 2009, 10:23:02 PM »
I shall send Franco of Ricambio an email to see whether the 123 electronic ignition will work on a BIS. I will revert when I get a reply. Come to think of it Rusty drives a 500.
