Author Topic: Sort of Sorting Sortie  (Read 5256 times)
Re: Sort of Sorting Sortie
« Reply #15 on: November 29, 2009, 10:31:24 PM »
 ;D I would suggest you contact the 123 makers via e-mail as I can see no reason why the 123 set up would not fit a Bis & your coil is OK , you do not need any other parts like ballast resistor or whatever. Off the top of my head I think there are 16 adjustable settings on the 123 to cover the standard 499ccs motor up to a highly tuned beast  [-/
« Reply #16 on: November 30, 2009, 05:13:41 PM »
I got a reply from Ricambio, quote, "this kit works with all the Fiat 126 models no problem. With the 126 Bis you already have the Electronic Coil on the car so all you need is the Distributor and a Ballast Resistor. The price of this kit would be £245 plus £10 carriage", unquote.
« Reply #17 on: November 30, 2009, 07:04:08 PM »
I have spoken to Proietti and Franco at Ricambio in the past. They will both try to sell you a ballast resistor as part of the very expensive but very effective kit. Just pulled this off another forum that confirms my knowledge of these things
"The purpose of the ballast resistor is to limit the current on a COIL/POINTS system and thereby reducing overheating/burn out of coils with the igintion left on; the points by chance being closed and the engine not running. This actually produces a direct connection to earth from the battery through the coil and hence is not a good idea.
With the 123 E System there is a built in cut out such that if the ignition is left on and the engine is not running then it simply switches off the circuit internally. Hence there is no need for a ballast resistor with this type of system. The coil came with a BIG notice warning about loosing your first borne son if I did NOT fit the ballast resistor but I checked with 123 and they confirmed that this was simply becasue the coil could be mated with conventional points....."
Did you check out the 123 people because if you had you would have been able to e-mail them to find out the best of the 16 settings for the Bis plus the details of the official UK suplier who did offer to do a special deal on the cap which would have been less than £150 including delivery.
« Reply #18 on: November 30, 2009, 11:22:43 PM »
The best place to buy a 123 system is sothern carburetters & injection see link
http://www.sciperformance.co.uk/onlineshopproducts_53353/prod_107225-123FIAT500PLUS.html
Taken from the site @ £159.95 plus VAT
The 123FIAT-PLUS is designed especially for Fiat500- and Fiat126-engines. It comes as a complete distributor, with a ring and mounting-bracket.
« Reply #19 on: December 01, 2009, 05:01:21 PM »
If that is the current price then that seems pretty good to me. One of the things that puzzles me is why the 126 unit is much more expensive the the other 2 cylinder air cooled one they do for the Citroen 2CV  :oops:
« Reply #20 on: December 01, 2009, 08:57:08 PM »
Does the Southern Carburetters & Injection offer an installation service?
« Reply #21 on: December 01, 2009, 09:40:05 PM »
Intresting, thanks for this info!
« Reply #22 on: December 01, 2009, 10:00:56 PM »
The ballast resistor reduces the voltage to the coil After the car is started. As voltage and current are inversely related this increases the current allowing for greater spark.
the idea of the resistor is that you deliberately design the coil to operate at a voltage lower than 12 V and then use the resistor to get to that voltage under normal conditions. When you're cranking the engine with the starter the battery voltage drops and hence the sparks get weaker. To combat this you bypass the resistor as long as the starter is operating. This gives you pretty much similar sparks during cranking and normal operation. It doesn't matter if you're running electronic or mechanical points.
The resistor is primarily there to allow the normall sparking to be un affected by the drop in cureent caused by cranking. I wouln't fit 123 without a ballast. Nothing horrible will happen, the coil simply wont last as long.
« Reply #23 on: December 02, 2009, 12:08:22 AM »
I think SC&I do a fitting service, check their website.
