As Mick said it is definitely one of the oil flinger's of the a/c timing chain, the other bits look like teeth off the timing gear.
I think your right some one has replaced the chain and sprockets and not cleaned out the sump
all the covers should be in place so the air is forced around the cylinders to keep it cool.
Check the valve timing while you have it apart.
Also make sure the ignition timing is set up correctly as some owners advance the timing to gain a little more power, but this does make the engine run hotter.
The head nuts should be tightened to 29 lbs ft or 40 nm
