Author Topic: hellllllppppp  (Read 5712 times)
Re: hellllllppppp
« Reply #15 on: March 16, 2009, 09:33:06 AM »
lol banjo you sound like the grim reaper lol, however very true.
neil did you check the oil pump as like i said on the phone it could be the pump has disintergrated and buggered up the timing chain and they havent looked at the pump that too could give you an overheating engine if the oil is not circulating
Re: hellllllppppp
« Reply #16 on: March 16, 2009, 10:47:19 AM »
Dunno about Death Death death... I ran mine for months without the hose as I was waiting for it to come..so the seller on e bay told me.
The same little engine took me to Kent and to Southampton, Dorchester and back, Oxford and back, totalling over 5000 miles now so I assume it isn't dead.. ;D
I think in the heat of summer it is not advisable.
besides without the big hose the the fan will pull and stray gasses and smells from the engine bay strait into the car when the heater is on.
believe me they need every bit of help to stop those stray smells and gasses! [-/
banjomandolin
Re: hellllllppppp
« Reply #17 on: March 17, 2009, 08:12:38 PM »
Mine fell off on a very hot summer's day. Fortunately I had fitted a temperature sensing device which measured the heated air. The temperature reading had shot up from 90 to 150deg.C. so I stopped to investigate and found the hose had become disconnected. I did a temporary bodge which got me home.
banjo.
John Clark
nrg19uk
Re: hellllllppppp
« Reply #18 on: March 23, 2009, 09:31:40 PM »
well i ended up stripping down the engine and couldnt fine anything major wrong apart from those bits in the sump with the very runny engine oil! so i sent the head off to be skimmed and got the dremmel out and some polish and gave everything a good clean and replaced pretty much all the seals gaskets rubbers there is!!! ive got some nice 20w50 classic to replace the runny stuff which has a nice smell of castrol/old engine smell :-)
heres some pics to keep you happy
http://i122.photobucket.com/albums/o254/nrg19uk/Photo1380.jpg
http://i122.photobucket.com/albums/o254/nrg19uk/Photo1388.jpg
http://i122.photobucket.com/albums/o254/nrg19uk/Photo1387.jpg
http://i122.photobucket.com/albums/o254/nrg19uk/Photo1389.jpg
http://i122.photobucket.com/albums/o254/nrg19uk/Photo1390.jpg
more pics later
Neil gargaro
Re: hellllllppppp
« Reply #19 on: March 23, 2009, 11:57:36 PM »
well done mate its nice working on an air cooled engine aint it?
nrg19uk
Re: hellllllppppp
« Reply #20 on: March 24, 2009, 06:14:27 PM »
very simple to work on!!! i just need to get a pair of manifolds and finish assembly then i can put it back in :-)
Neil gargaro
Re: hellllllppppp
« Reply #21 on: March 24, 2009, 07:43:36 PM »
i have some if you want to hurry things up , and your vents and some old rear lenses if you want them just get your bum down here .
nrg19uk
Re: hellllllppppp
« Reply #22 on: March 29, 2009, 12:35:22 AM »
cheers mick your a star!!!!
Neil gargaro
nrg19uk
Re: hellllllppppp
« Reply #23 on: April 04, 2009, 07:03:33 PM »
right i have the engine back in! but no spark where abouts do the cable go from the dizzy and the coil etc??  also i have a cable with a 1.5 amp fuse in which has blown any ideas?
i have a bit of confusion as to the timing side of things i have set it to 10o at tdc and set the dizzy to spark plug one just opening and still no spark!!
what are the cables coming out the back of the gearbox?
Neil gargaro
Re: hellllllppppp
« Reply #24 on: April 06, 2009, 09:59:00 AM »
Cables out the back of the box are for the reverse light switch.
From the Dizzy it goes to the negative side of the coil.
Check there is power at the coil
Check the points are making contact when they are closed, may seem like a silly thing to say but some sets of points just stop making contact for reasons I can never understand which is why I am saving pennies to get electronic ignition! [-/
nrg19uk
Re: hellllllppppp
« Reply #25 on: April 14, 2009, 05:45:56 PM »
thanks for the reply darrell ive only just noticed it!!
i sorted the spark problem the coil had some grease between the earthing point! i wonder how many people have brought new coils thinking they have given up the ghost!!
Neil gargaro
