Author Topic: It begins.  (Read 4366 times)
K666STW
  • 704cc of pure fury.
It begins.
« on: February 28, 2009, 12:26:38 AM »
 Well after a fun drive home in the little BIS the problems have begun.
What had been a silent exhaust up until about 20 miles from home started to bang. I suspected it might have been the exhaust banging off the engine block, further inspection leads me to believe it is in fact the baffles inside the back box. So it looks like my first broken part is the exhaust. :D
But today I got 2 little surprises.
First was on the way home from a mechanic mates garage the car would suddenly when under half throttle die or stutter. Foot on the accelerator however sorts this, although it's not ideal. One of the sparkplug leads has a broken thread and doesn't seem to connect with the spark plug very well. Could this be the cause?
The second was once I got home from said mechanic mates garage I parked got out the car for a neighbour to come over and ask me about the little fella. I immediately started to explain how great it is, when the little bugger started to pee on the drive. :(
The bottom radiator pipe has been rubbing on part of the metal frame that it runs close to. This has resulted in a little crater in the pipe with a tiny hole in the center. Can a hole in the center of a pipe be patched? I'm still new to actual oily fingers mechanics. I'm usually more of a theoretical spanner monkey.
Re: It begins.
« Reply #1 on: February 28, 2009, 08:08:20 AM »
Aren't they great :D Not like owning a Japanese modern car at all, always a little suprise in store.
What is going happen today ::)
Welcome to the world of the 126. Just think how happy you will be when it all fixed.
Re: It begins.
« Reply #2 on: February 28, 2009, 12:38:32 PM »
Lets be realistic... its never "all fixed"  :oops:
the throttle problem could be that the carb is dirty or the jets are clogged, or could be something else :D not sure about pipe patching, maybe as temporary untill you find the right pipe...  [-/
K666STW
Re: It begins.
« Reply #3 on: February 28, 2009, 03:02:14 PM »
Well have managed a temp fix on the hose.
Removed the section with the hole and put a smaller piece of hard pipe in between with jubilee clamps either side.
Managed to improve the connection on the ignition lead and it made no difference to the running issue. So the carb does sound like the next logical place to investigate.
Re: It begins.
« Reply #4 on: February 28, 2009, 04:02:34 PM »
 ??? What do you mean by broken thread on spark plug lead as they should just push onto the plugs & coil  ???
Re: It begins.
« Reply #5 on: February 28, 2009, 04:49:01 PM »
Check the points first and work your way through it ;)
K666STW
Re: It begins.
« Reply #6 on: March 01, 2009, 01:21:55 AM »
Threads was the wrong word to use sorry. What I mean is the female of the ignition lead had a small section broken off. Meaning it wouldn't sit securely like the other one does.
Car is now refusing to start. So will have a poke about the points tomorrow in the hope that is all it is.
Edit: My dad is on holiday and won't be back for a few days. He is my technical help on this as he is into his old bikes ( he has a Ariel Arrow modified to Golden Arrow spec)  So what is it I need to do with the points?
Lee who sold me the car said the points might be the only issue I have. But I never asked him to show me in more detail than he did. Never thought I wouldn't have my dad there if it arose.
« Last Edit: March 01, 2009, 01:53:31 AM by K666STW »
Re: It begins.
« Reply #7 on: March 01, 2009, 07:11:21 AM »
 :) I asked about the screw thread thing just in case you had lost the terminal from the top of one of your plugs. Also I have a set of used but good plug leads for a Bis left over from the days when I had a new one. You can have them for the cost of post and packing if your ones are damaged. £2 would cover it easily  [-/
K666STW
Re: It begins.
« Reply #8 on: March 01, 2009, 12:31:28 PM »
Nice one bud.
Although I have no paypal account so will need to wait till my dad gets back from his holiday so he can send the coin for me.
How sad am I? 30 in 4 months lived outside the family home for nearly 12 years, but am still lost without my daddy. :p
Re: It begins.
« Reply #9 on: March 01, 2009, 03:24:30 PM »
 </ As my son is 30 in 7 months time I can be your stand in Daddy ! Just send me your address and I will put them in the post asap then you will have them to hand for when your real Daddy gets back. Us old grinners do have our uses from time to time  ;)
K666STW
Re: It begins.
« Reply #10 on: March 01, 2009, 03:34:02 PM »
Superstar.
PM sent.
thebowman
Re: It begins.
« Reply #11 on: March 01, 2009, 03:54:21 PM »
Hi mate
sorry shes starting to cause problems for you, I found if she was chugging or pulling a bit the screw holding the condenser in place had come loose causing a bad conection hence the chug, its a bitch to get at the screw though need someone with little hands.
hope she plays ball soon
cheers
TheBowman
markie
Re: It begins.
« Reply #12 on: March 01, 2009, 06:25:39 PM »
LoL!  this is truely just the start of many black handed weekends but it sounds like these are all things that can be cheaply fixed unless you later find that the actual cause of your water leak is due to pressure caused by the head gaskit going.  Believe me this is just periferal stuff.  I think I'm gonna start a new discussion on catostophic failiers.  ::)
K666STW
Re: It begins.
« Reply #13 on: March 02, 2009, 01:45:19 AM »
Lee don't worry about it. I've had cars long enough to know sometimes these things happen. [-/
I'm just a bit more use to sensors or ecu failures than actual mechanical gubbins.  :)
K666STW
Re: It begins.
« Reply #14 on: March 12, 2009, 01:44:50 PM »
Hey Dave have PMed you a few times but don't know if you got them. The leads arrived in good condition. I still need your details though so I can send the money for the postage for you.
