Author Topic: It begins.  (Read 4366 times)
K666STW
  • 704cc of pure fury.
Re: It begins.
« Reply #15 on: March 13, 2009, 02:55:33 AM »
Got your message. Replying here in case pms mess up again. :)
Re: It begins.
« Reply #16 on: March 13, 2009, 06:38:30 AM »
 :) Cheers Mate , Hey you are not an insomniac are you ?
K666STW
Re: It begins.
« Reply #17 on: March 14, 2009, 02:29:48 AM »
Nah mate, just work funny shifts.
I'm a wreck without a solid 14 hours a day. :)
On another note. Is there anywhere I can find the workshop manual for the BIS.
I've tried searching but keep finding dead links.
Eklipze3k
Re: It begins.
« Reply #18 on: March 14, 2009, 08:37:50 AM »
There's stuff in the Subscribers section if you donate :)
K666STW
Re: It begins.
« Reply #19 on: March 23, 2009, 01:48:14 AM »
Well got the little one running again today.
My dad finally managed to get up to look whilst there was daylight. The problem seems to have been the wire connects to the points. It had broken it's solder point on the "points arm?" and according to dad been a fix from before as the wire should have been multi-core or something to deal with the movement it deals with. So a temp fix of a longer wire that spirals inside the casing once so there is less strain on any one part of it and a new set of points to be ordered. Unless I can find a suitable electronic ignition system first?
Still waiting on the new coolant pipe and exhaust to be delivered!
