Author Topic: Oil cooling  (Read 1305 times)
Oil cooling
« on: January 23, 2009, 12:55:49 PM »
How about an Oil cooler....with a fan! or two.
Motorcycles have very small electric fans, I wonder if they would be good.
Might help get hot air out the engine bay too [-/
phreak97
  • Niki!
Re: Oil cooling
« Reply #1 on: January 23, 2009, 01:40:46 PM »
i think to cool the oil is harder than it sounds.. you have to devise a way for the oil to pump out of the motor, through a radiator, then back into the motor.. sounds like a lot of work to fix something which doesnt seem to be that much of a problem really.. how often to aircoolers overheat? i've never had any trouble myself..
i think the kit to hold the engine cover open a bit is probably the best way to go. otherwise i dont see why you couldnt attach some fans to the inside of the vents just to get some more air out. if you need help with the wiring just say so:)
phreak97
