Author Topic: FIAT, NEED ADVICE  (Read 1666 times)
devilkiller
FIAT, NEED ADVICE
« on: January 18, 2009, 07:56:37 PM »
HELLO  JUST JOINED,GOT A 1980 AIRCOOLED 126,IM LOOKING FOR SOME ADVICE IF ANY BODY CAN HELP ME?
« Last Edit: January 18, 2009, 08:00:53 PM by devilkiller »
Re: FIAT, NEED ADVICE
« Reply #1 on: January 18, 2009, 08:08:23 PM »
Hy, i dont mean to be rude, but you should start of by introducing yourself in the introductions section, then post your problem in the section you need, electrical or mechanical, and im sure the good folk of this forum will gladly help.
With respect, Gordan  [-/
devilkiller
« Reply #2 on: January 18, 2009, 08:15:06 PM »
sorry new on comp i had an old w reg gave me by an old boy at work  i started it over xmas a few times then i pulled the starter lever and its came of at the back iwas just trying to find out where it goes to in the engine bay sorry again
« Reply #3 on: January 19, 2009, 05:51:03 AM »
No need to apologize mate, just introducing you to the forum  ;)
oh, and welcome.
Sorry i cant be of much help with the deville, my bis has a modern starter system, so its kinda different. If i understand correctly you pulled the pull lever wire out? It should be connected to the starter motor, if im not mistaken  :P
markie
« Reply #4 on: January 19, 2009, 09:59:04 AM »
Hello,
the starter motor is situated to the lower right of the bell housing behind the exhaust,  I suggest you get a haynes manual before you start.  You can get a replacement cable on ebay or any one of the good online fiat supplyers, i advise you get the retaining clip for where the cable attaches to the lever at the front or it will constantly be falling off every time you go to start it.  Also make sure that the starter motor has its rubber cover on the positive connacton, this is a constant live and if the new cable accidently comes into contact with this you will end up with a glowing red starter cable, this is not good.
Attached pic shows bell housing with engine out, startey motor to the right, starter cable removed hanging by the driveshaft.
« Reply #5 on: January 19, 2009, 10:22:44 AM »
hi and welcome to the club126uk forum
the starter arrangement should be similar to the picture below
devilkiller
« Reply #6 on: January 19, 2009, 02:46:55 PM »
ok cheers for your help will i have to take the splash pan of the bottom of the car to get to the starter ???
