Fiat 126 Chat
Tuning & Customising 126 Models
twin carb conversion
Pages: [
Topic: twin carb conversion (Read 4039 times)
PINK BUT NOT FOR LONG!
on:
January 16, 2009, 12:22:29 PM »
Hi, i recived my twin carbs off ebay today. ive got a pair of kei-hin's from a er500, wish me luck.. getting the manifold made up for me... alond with the motorcycle exhaust!!!
wish me luck!
Re: twin carb conversion
Reply #1 on:
January 16, 2009, 12:44:16 PM »
Unless you have a special head with two separate inlets, I would imagine one of those carbs would do the job easily.
Have a look at the blitz buggy link I posted somewhere.
Not the only African in the village
Reply #2 on:
January 16, 2009, 12:51:59 PM »
i was just thinking of a 2 into one manifold to attach both to the head...
Reply #3 on:
January 16, 2009, 03:29:53 PM »
and one of these.. i wont be able to have my boot lid on.. but ill sort something out
Reply #4 on:
January 17, 2009, 11:50:55 PM »
need to make something like this
Subscribers
Reply #5 on:
January 18, 2009, 05:49:55 AM »
Wait, doesnt the bis have a twin carb?? What does this one do that the stock cant? Im not saying anything, just asking...
PLEASE FOLLOW MY PROGRESS ON IG:
https://www.instagram.com/fiatbis/
Reply #6 on:
January 18, 2009, 03:28:19 PM »
no, single carb with twin choke...
ill be replacing my 40mm webber with two 38mm carbs from a kawasaki, ill also be upgrading to an electronic fuel pump.. the engines getting an overhaul first..
Subscribers
Reply #7 on:
January 18, 2009, 05:15:53 PM »
Reply #8 on:
January 20, 2009, 04:17:39 PM »
Looks easy now ive seen this pic.. just a case of modifying the manifold and attatching to bent pipes... jobs a guden...
Subscribers
Reply #9 on:
January 20, 2009, 05:03:17 PM »
Id go for a tube based fanny mould, just make a set of flat plates to bolt to the carbs and engine then cut a piece of appropriate carved tube and weld it in between....
Reply #10 on:
January 20, 2009, 05:32:32 PM »
explain that a little better stuey... i was just going to use the gasket (pictured) as a template, and then machine it out of 10mm steel, the weld two pipes on to it..
My carbs have rubber connectors on them to connect straight to engine
Last Edit: January 20, 2009, 05:50:15 PM by Paulh81
Subscribers
Reply #11 on:
January 20, 2009, 06:16:22 PM »
ah then do what you said then..... I thought the carbs had a mounting plate of their own...
Pages: [
Fiat 126 Chat
