Author Topic: Alloy Wheel Size?  (Read 3318 times)
custardboy
Alloy Wheel Size?
« on: January 12, 2009, 10:09:38 AM »
My air cooled 126 is running on 13" alloys with 155/65 tyres which I think are bigger than standard, seem ok but can catch a little on front arches when turning steering.
I have been offered some 13" Cinq alloys with new Pirelli 165/55 tyres, would these be a better fit and what difference to speedo would they make?
Eklipze3k
Re: Alloy Wheel Size?
« Reply #1 on: January 12, 2009, 10:11:13 AM »
« Reply #2 on: January 12, 2009, 01:13:06 PM »
ive been told thet 165/55 is the largest tire you can fit on a BIS without rubbing, dk if theres a difference with aircooleds. Anyway im getting my self 165/55 too so you tell me how you get on...  :D
markie
« Reply #3 on: January 12, 2009, 03:04:35 PM »
Hello Guys,  I studied this for a while before getting my 14" 5J wheels.  Wherever you go you will be told that you can't have 14" alloys  but as long as you can source 155/50/14 tyers then you can!
You will find you have a lot more choice of wheel if you go upto 14" and the combination below fits perfectly.
135/80/12 pretty much = 155/55/14
see http://www.tyresave.co.uk/tyresize.html
NANKANG TYRES £34 EA @
http://ssl.delti.com/cgi-bin/rshop.pl
All the best
Eklipze3k
« Reply #4 on: January 12, 2009, 03:18:18 PM »
Most 'cento owners have labelled Nankangs as "Ditch finders" ... I take it they're not so bad on the Maluch?
markie
« Reply #5 on: January 12, 2009, 06:00:17 PM »
You could be right, I don't know but mine have been fine and if they are on a 126 top speed 65mph then I don't think you have to worry about driving into a ditch unless you are visually impared.  My original 1978 126 used to run on any old 135 remould and I only ran into a wall once, the wall came off worse LOL.
Just trying to help.  I did find the tyre size calculator VV handy, gives you a real example of how tyre size will work out.
custardboy
« Reply #6 on: January 13, 2009, 08:01:54 AM »
I have used the US Miata owners club wheel calculator which is good but this one  www.kouki.co.uk/utilities/visual-tyre-size-calculator is very effective.
I have since found the standard tyre size to be 135/70/13, therefore my 155/65/13 are causing a 2.5% increase in rolling circumferance, effecting the speedo slightly.  The 165/55/13 should be fine so long as the extra width does not catch on the front.
« Reply #7 on: January 16, 2009, 09:58:52 AM »
ha ha i like what you say about the nankangs! the old profile was very square and i found they tended to let go easily on greasy roads , pirrelis i have found that i spun out more on round abouts than i would like as they are a summer tyre , the new nankangs have a rounder profile and different tread pattern and compound and so far i only get the car sliding when i want it to and hasnt given up yet on hard corners at speed even on the wet greasy surfaces that are here now. the other difference is your cinq/sei are front wheel drive and need to be driven differently.
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« Reply #8 on: January 18, 2009, 11:47:13 AM »
mick ?
« Last Edit: January 18, 2009, 12:05:33 PM by bobblehead »
