Author Topic: Cooling System, Water Filler Cap.  (Read 4718 times)
Gregozo
« on: January 10, 2009, 11:49:58 AM »
Hello! New to 126 ownership and having some issues with the cooling system - so what's new I hear you all say from having read quite a few posts on this subject! but one thing I can't see mentioned is wether or not the water filler cap should be 'pressurised'. After a relatively short run water is coming out of the filler cap and low coolant light comes on. When I squeeze the big water hose on top of the engine air can be heard going in/out the filler cap freely. Looking at the cap it doesn't seem to have any spring in it to hold any pressure in the system as per 'normal' radiator cap. I appreciate why the system should be pressurised to raise the boiling point of the water in the system, so can't imagine 126 system is unpressurised??
Any help gratefully accepted....
Re: Cooling System, Water Filler Cap.
« Reply #1 on: January 10, 2009, 02:10:32 PM »
The cooling system should be pressurised (as far as i know) the water cap has a pressure pont when it starts releasing steam/coolant in order to save the system from exploding. try to replace the cap, it shouldn't be expensive, and i think its universal (i fitted a cap from my brothers Aprilia SR50 scooter). Let us know how you get on
Gregozo
« Reply #2 on: January 10, 2009, 04:36:36 PM »
Thanks for that Gordon, I am sure the system should be pressurised too, can't see how it can not boil up otherwise. Does anyone know how the cap works - is it with a relief valve type spring that will re seat itself  if it relieves pressure or a rupture disc type that is a 'once only' relief. I can blow through the hole in the cap with no resistance what so ever, which can't be right.
« Reply #3 on: January 10, 2009, 08:13:41 PM »
The point of the cap is to let out air when the temperature rises in the system
(fluid expands,bubbles in the system), and to let in air when the temperature is low. I'm not sure if the cooling system in the BIS is open or closed, but there's a valve in the cap which opens or closes with the aid of a spring.
Gregozo
« Reply #4 on: January 10, 2009, 08:32:31 PM »
Errr, no it's not, the cap is a relief valve which keeps pressure in the system to raise the boiling point of the water in the system so it doesn't boil at 100c but considerably more (like a pressure cooker works). Cap on the BIS is nothing like the picture you have posted, which is what I would call a 'standard' rad cap, it's a plastic thing with a hole in the middle which. on mine, is free flowing when I don't think it should be. I have never had such a basic car as a 126 so I don't know what to expect! - and I used to have a Reliant Regal which was probably more sophisticated!!
« Reply #5 on: January 11, 2009, 06:37:04 PM »
If there's no expansion tank, then you'd have coolant coming out of a pipe under the cap at the top of the radiator when the temp. rises. This is an open system. Systems with expansion tanks are closed. Yes, they have different looking caps, but work the same way pretty much: at high temperatures it lets out air, at low temperatures it lets in air.
« Reply #6 on: January 11, 2009, 09:29:38 PM »
The Bis has an expansion tank!
Gregozo
« Reply #7 on: January 11, 2009, 10:19:33 PM »
Yes thank you at last someome who knows what they are talking about! as you can see from the diagram the pressure in the system should be 0.98 bar  which is what the cap should keep in the system and relieve if goes over that. My cap is obviously buggered and I need to get another one!! No wonder everyones 126 is overheating and blowing cylinder heat gaskets if you think its an open system!
Will get a new cap from somewhere ASAP and hopefully my problems will be over.
Cheers Greg
Gregozo
« Reply #8 on: January 11, 2009, 11:30:30 PM »
FYI @ 1.98 Bar boiling point of water is 248f / 120c so essential system pressurised.
« Reply #9 on: January 12, 2009, 04:55:41 AM »
the water cap has a pressure point when it starts releasing steam/coolant in order to save the system from exploding. try to replace the cap, it shouldn't be expensive...
hate to say it, but told you so  :P ;)
Gregozo
« Reply #10 on: January 12, 2009, 08:07:51 AM »
"The cooling system should be pressurised (as far as i know)"
Well we both know now it is pressurised and thanks to excellent drawing from ciaoflyer know how it works.
« Reply #11 on: January 12, 2009, 09:39:25 AM »
All along i was basically saying the same thing. The diagram shows whether or not the cap works, cos if the temp rises, fluid expands, then the pressure rises also. So if it doesn't let out air, then yes it does strain the cooling system.......
Any cap has a relief valve which is calibrated ,so it opens when it reaches a certain pressure/temp, but closes when the pressure goes back to normal.....
« Last Edit: January 12, 2009, 10:13:23 AM by GTMaster »
« Reply #12 on: January 12, 2009, 11:01:35 AM »
this thread sounds like its gaining too much pressure too! calm down....
« Reply #13 on: January 12, 2009, 11:04:48 AM »
sounds like it could do with some...air too cool it down  :P
« Reply #14 on: January 12, 2009, 01:15:19 PM »
Seems like if wee keep this up the mods are going to have to skim some heads  :D :D
just kidding...
p.s. what if i lets say put a cap on which has a release point of 3 bars  :P :P
