Author Topic: FSM 650 (fiat 126)  (Read 2283 times)
Brian
FSM 650 (fiat 126)
« on: July 25, 2008, 04:39:45 AM »
Hi My name is Brian I live in Perth West Australia I have a Niki 650 and I can not find the windscreen washers can some one please help Me?
I was Born in Dittisham South Devon 1946 moved to Australia 1971
FSM 650 (fiat 126)
« Reply #1 on: July 25, 2008, 11:02:30 AM »
Not sure if i understand the question but here goes-
windscreen washers -
Bag and pump for the washing liquid-
Hope this helps. Gordan
Brian
Windscreen Wipers
« Reply #2 on: July 25, 2008, 02:26:33 PM »
Can I refraze that I do not know where the washer button/switch/lever/knob is, it is not on the wiper stalk. :smt021
phreak97
  • Niki!
FSM 650 (fiat 126)
« Reply #3 on: July 25, 2008, 03:02:35 PM »
it is on the wiper stalk:) you pull it towards you, it doesnt feel like it clicks or anything, but it does work. if the jets are pointing in funky directions the nozzles are adjustable, takes a bit of playing to get it right though.
also, if youre filling up the water, it's the vinyl bag in that photo, not the plastic tank.. it'd be bad to get those confused.. the plastic tank is the brake fluid.
another unrelated tip for new niki (or 126) owners: when putting it into first gear, always be completely stationary, and always put your foot down on the clutch, then put it into second, then into first, then let the clutch out as normal.. doing that will stop the crunch and an expensive rebuild down the track. it doesnt take long to become automatic.. i find myself doing it in my other car too, even though it isnt necesary in that.
phreak97
FSM 650 (fiat 126)
« Reply #4 on: July 25, 2008, 03:12:26 PM »
If it is an early one it is a rubber thingy in the middle of the dash. Pump pump and pump again until it works  :???:
phreak97
  • Niki!
FSM 650 (fiat 126)
« Reply #5 on: July 25, 2008, 03:18:01 PM »
it wont be an early one, we didnt get 126's in australia till the late 80's, and every model is the same except some differences in part stock.. itll be on the wiper stalk:)
i'm getting to know alot about nikis:)
brian, i also have some spare parts here if youre ever after anything.. shipping within au should be cheap and i wont charge much for the parts, i like helping out fellow niki owners:)
phreak97
FSM 650 (fiat 126)
« Reply #6 on: July 25, 2008, 03:31:01 PM »
phreak is becoming a real pro at this....  :D  :wink:
Brian
Thank You Phreak97
« Reply #7 on: July 26, 2008, 08:28:21 AM »
Great info Tried the Pull option works a treat, Also thank you very much for your kind offer of spare parts i will certainly keep that in mind.
Many Thanks Once Again
Brian
phreak97
  • Niki!
FSM 650 (fiat 126)
« Reply #8 on: July 26, 2008, 01:31:35 PM »
youre quite welcome:)
phreak97
